shortbusjeep
ok well it seems this subject is old news now that moabs are out, but i know i havent ponyed up the cash yet and im sure there are still some cheapies out there like myself who still need to soften up some tires. i looked around and have tried to gather all the threads on it and the ideas i have used if i missed a thread or you know of a trick post it up here.
1. Simple Green, and Rubbing Alcohal. -- i used this on my LSTs and they are uber stickie now and it seems it will last pretty good, they were already on rim so i filled up a gladware container with a 1/4 of the simple green and about 3/4 the rubbing alcohol. let each section of the tire soak about an hour.
2. wd-40 and heat-- worked alright but didnt last long i was doing it to my gs racing tires every time i would crawl would last like a battery pack, spray wd-40 all over the tire tread, let soak in around an hour or longer, then before i left to crawl, i would just run over the tires with a propane torch to get rid of the shineyness.
3.http://www.rccrawler.com/forum/showthread.php?t=14015&highlight=softener
has alot of ideas
4.http://www.rccrawler.com/forum/showthread.php?t=6567&highlight=softener
where i got the simple green and rubbing alcohol from
5.http://www.rccrawler.com/forum/showthread.php?t=16505&highlight=soak
Diesel softens rubber!
6.http://www.rccrawler.com/forum/showthread.php?t=15655&highlight=soakAdolf's Meat Marinade
7.http://www.rccrawler.com/forum/showthread.php?t=5899&highlight=soak
VHT
8. saw in threads not worth posting up, GOJO -- also brake fluid-- and bleach--
9.flame on-- propane torch
hope this helpes everyone make sure you guys post up the ones i missed.
shortbusjeep
has alot of ideas
VHT
shortbusjeep
