Supershafty CP43
Col_Sanders
Embrace the Chaos
Subscribed Member
Arkansas
These caught my eye a couple years ago but the price tag pushed me away. As of today, a front axle is $439.99 and a rear is $269.99. When you can pick up a new set of take off F10 portals for $200, the $700 price tag is pretty high. But you fully deck out those F10 portals things change. A new front and with all the aluminum upgrades is $465 from vanquish. Rear is almost $350.
Anyway, figured id give some pics with other axles for comparison...20250424_184106.jpg20250424_183429.jpg20250424_181122.jpg20250424_180800.jpg
They have more caster built in than the F10P and AR45. They also have a mm or two more ground clearance than the F10ps, and a smoother profile so they should slide over rocks better. They are also a few mm wider.
The CP43 universals have much larger pins than the F10Ps and the ears have been profiled to allow better steering angle. Stub shafts on the CP43s are smaller than Vanquish, as is the bulk of the axleshaft. The part i keep breaking on the F10P is right outside the spool and theyre the same size there. Im not a metallurgist so cant tell which shafts will actually be stronger.
I just bought the housings, which come with everything you need to swap ar45 or Capra axles over, but they came with no rear upper link riser and the high profile front upper link mount, which wont work for 4 link. In hindsight i should have just bought complete axles and sold the ar45s.
The strength of the axle shafts is not just about the metallurgical properties, it can be about stress distribution.
If you are currently breaking the axle shaft just outside the spool where the shaft cannot be made thicker or bigger to strengthen it, then making the shaft outside of that a bit smaller can actually move stress from the over stressed breaking area out to the long part of the shaft where it was not being stresses to the maximum. If done correctly it distributes the stress enough that no 1 part is overstressed eliminating failures.
Basically, the skinny part of the shaft flexes a bit more taking stress away from your failure location and stopping the failure from happening or at least increasing the time until failure.
I've wanted a set for a while, to go with the SS CP44 Capra axles I have on my G-Shot. They are awesome, but pricey! I have never had an issue with mine!
Ive broken two. First one was entirely my fault. Winch line got wrapped around the tire on gate 8 or 9 and i had seconds before timing out so i sent it and SNAP! The second one was odd. Had not been in a bind or anything all day or the day before. It broke on really mild terrain. No noise or anything. Tire just stopped pulling.
I like using the same axles on multiple rigs. If these hold up i might but another set.
Something i wasnt too keen on is that these are set up for Axial width rod ends. If you are using a Traxxas rod end like most link kits cime with, they recommend adding a washer to reduce slop. Or Axial sells a pack if 10 pivot balls AXI234004 for $27.99 on Amain. Another option i just found out about is Dlux. $0.50 each. Pic with Traxxas rod end:
Wtf. $30 for pivot balls? I was thinking it's a $5 part (in line with what dlux charged). Horizon just trying to win more people over....
The axle scope creep is real. Didn't take me long to go from stock AR44 ---> SSD Diamond ---> built Pro45 ---> Wizard TKO ---> Dlux built Capra axles on my builds. I'm scared of what I'll probably buy for the next one.
Haven't yet had the opportunity to try out anything from Super Shafty, your axles look killer. What rig will you be testing them out on?
I also stock my parts boxes with the Dlux pivot balls in all sizes. Despite the very expensive (and very nice) stuff they sell, they're pretty reasonable on their small parts.
I'm sure the Dlux axles are very strong but I just don't like the way they look. Function over form I guess.
They are going on my newest build, a Poizd T3 Thumper. There's a thread over in the 1.9 section with more details.
The bumper has been straightened out since that Pic lol
I think its powdercoat? You can see on the rear wheel, the finish chipped off by the hardware. Thats just from tightening it down (not gorilla tight mind you). He said he will not be using that finish again. I ordered a set of orange 1.9s yesterday since they were on sale and I think I may send them off to get Cerakoted this color. Or I may just just be a cheap ass and rattle can them.
I love the looks of these wheels, but wish he'd do something like Lockedup's EZ mount. Undoing all these screws is a pain, especially when using scale hardware.
