Team Berberg's 2.2M SuDu Pro XR10 revival
MikaelBerberg
Norway
I have always wanted a MOA, and when I recently came across a SuDu Pro XR10 very cheap I jumped on the deal to get a decent entrance in to the 2.2M class :)
It has already been built and driven many years here in Norway.
Here it is when I recieved it:
ACtC-3eacfGZYX0u7F3hwfU-ehVQt1h80geNhWxJ8H54FDMlroLC1vQhNmV_hpjn5L2BMDmSFD3VN7xw9FQctj7vp5V0NKdAQ2b3Sxf9T34yFO0wE0cPnWzvfb59CLahKfU64_qRseJlXe1lgHX5NhI_ciqO=w1250-h937-no
ACtC-3co214swU33JCmiYXOYoXYcsco0uVH_pe911a9iFmeHlwvv1SP-Mys03wxEafSTWkEH770ao3mj-0cXk-jU5X5hJUASUNbtUe55KaU6ipDFzkdfR5RUlbFDjqjBwLuGsuMfTrKtA9DKdocnFRUQs6J_=w1250-h937-no
ACtC-3cdaMBXn6Z0zJHS0oav6rjByfc-fq9ZvpAyHKjGsZARmQOjfKSs_yW4rTu4FHuaDKcmJw_q4vgAo0Vrq0J9cU4_Nk-Z-gQZ8SS_hXE1S9-4IO_mb4oI9gmSm_t29p9XY2dMqsoPCpyohRPskcfx_Zyp=w1250-h937-no
Removed the wheels and that awful aluminium roof panel to get a better view of what I'm working with.
Its got some really nice parts, but its in desperate need of TLC :shock:
ACtC-3cIj7qMqEbUeQjK3xIV6rEZ3_v_Hp4bb_mTQESXkVgH4Xq7LEqjN3v3i_dYygNw-hVyDaKLm4k4YE5Mpeg02FJ2LLmhYTvFOQjueF8drUEaD9iUIDCyiOAosrKKeIys_8ALXuUDONQbTDGwhY3bzqW8=w1250-h937-no
ACtC-3dK9aVH7Lxgqs6xgpAipsPzBnUKMlXIjVwWSHSfuFROCgfbMb_mQ4Pyla3b98mCNix_Qy4R0M-KqQUbM54INUc9kDai6bBCwXmnOKWuIUsIqqcxg-0a7ov2FXeWp4XNtF6leEjv9GLXTkWtlJNDgkX7=w1250-h937-no
ACtC-3fWLrzXM-7Nq3AMmlAchuGbtJKcFAsI8xgGUHzaAx9dOU7i63Pj2chPVLgfJzushaTCCbQj0q4GrBTXr3H6exCMRuBgLDrPzIzgxVQyyyn36sq4BTG7cAv6Ej6kyEleXVq_aPEY1Dvkx0y7Qs70Vu1e=w1250-h937-no
ACtC-3fr2X3qSAqG4eVfW-UvvlOkUOBYvMe7N_2EmP0lg0mcG5wHut3FQLZ3leGJUaiMSpCc15dSk490e5nX0UxX8XhCpGV56r9NMjQ85VNBUFSkgq329TXHKOf4QzJwd2ybfynAT1bBhqy4MZ3udwARBLZX=w1250-h937-no
The axles are pretty well built from my understanding, but I disassembled them to give them a health check, swap bearings and grease them again.
Lets start with rear axle
From my research, these are the specs:
- 2 bolt mod
- CreeperBob titanium axle shafts
- All Axial Machined gears
- Titanium upper shaft
- Traxxas Oilite small bushing (I replaced this with new oilite)
- VP alu transmission housing
- Krazed Builds motorplate and upper link mount
- BWD Blade stiffener
- Axial alu lockouts
- Team Brood Creep 35T motor (I timed it to 0 degrees on the rear. Brushes are OK for now, will need new brushes and comm cut soon)
- Delrin motor protector
Disassembly and check
ACtC-3cYA2VyDJN1m024t7ErqDXx2bR9kI06K-LEC2xqZ21iEprBpZl926JFDSPSZA-UOdXB7mRVRWW_YyrzFmhfQJAsKUHC_LjlFSIag1wyWKyVsmQuF5m92cDqRSY2o37O6WBzTVJ7ngHaY5Khpeeyz7Bs=w1250-h937-no
ACtC-3fmwe_pAKmX0jWStDUFyXcH4jZs85CNUNRTA-ZqVjz-3dAjmFn813sC9UArPT1VR3ldQEVWiMYPAdElDjW_E1-BAMo5PYDX4AYsqOm483oC_bMffgw1jiA2JF8MwOi0ZpePE5GzZmd3gTv-BhTkIubJ=w1250-h937-no
ACtC-3eR-qf45pO196xbw_PJVP3sCrenrNNZExdhXF3nffdEyOyHdoe3BNhuEzCodvd-Tzo-AjI6aRbLfP821Ic3vlY2m46okZ3-_norc00YPfnfWu36kDu0gTcgY2N-kmR2sT9IZmd2Nr_wkPbLmD2Nug69=w1250-h937-no
ACtC-3f1g1qAQA0v6YwhoYJwNL9G5m0bXOJUuzYgWScSqtNlOfSJCPDtkzDblCPtWrcNjzFMaqW6n-868ntjedL-D9otLEbYCBpcblXxFA7S5CApZNwS0IheO2uVNl7MqpB0YW5h6x1Xj5Hgob6JIv_5ey2w=w1250-h937-no
Back together with new bearings, some new bolts and a thorough clean-up!
ACtC-3dAFPXyFjxpguUsC2kBp8UkfgWSymDN6lTGfPV2PRiKkPvX1aZap3GWzV8S7wrMv-elnaBpU89an5ggdUF-qCDhnOGfNgKZgMS_oUBGvK3OEcfj06mFdOQD-8Z3Dhb2Kx-fnxPMJ7dW4-gj1YGkycsV=w1250-h937-no
Back together with new rod ends (5347 for lower 4mm and 1942 for upper 3mm). Will attend the shocks later
ACtC-3dWpaVMqOi2GBLSjSdHY0_QnZOFTSb27vXS0-AlzfxzIWkjq8F9FcjFw1q8cfYEZEC4oD37qZ83TyCKB41flcfKXKihjN6zMejw_ZlOcTxY8uzYliHgT2zNpJTTvSMFf1ZYsHwUCSJ36BrYEHGtfs_1=w1250-h937-no
I then proceeded to do the same thing on the front axle,
specs:
- VP Upper link mount and servo mount
- VP C hubs
- Dlux brass knuckles
- Rowdy Racing battery mount
First of I started by cleaning the really bad knuckles
I removed the slugs inside the knuckles and addifitonal brass ring, as I felt the knuckle provided enough weight itself. I will play around with either Loaded Dice or Pat's weight hanger later on.
ACtC-3eddSuTQflU6BCmqDW8gdNKRF3Q7Bm6LA_DakvVxYRA79c7x5-TdcCUUcyAQWgPXDgV7wmexINllIrT7xt-s8p64R4wvZD412dbTc79N0WiKID6UQ88YdyASAXz5Vj6_jEDFNkZ32yW3qVpcqmbRPcb=w1250-h937-no
After new bearings, grease and a new bottom housing, put together again:
ACtC-3dGev_0qSxTNtdScL9iMB5OpnqZC2O_V0d-6LkvMIseRpt2OJ1UER0ft9xyqFA4ZoyMQbiRNb3MCXQuu41iTmtJ7iRXOkowKJOGK34f14m7avmYnGSnTqdVpcrtvPUmkCL6L0WprRCDyrfbYJ3kjbLw=w1250-h937-no
ACtC-3cxwxjCyjKmwaZMgLRiWG-iaCPJUJT9u2H-iGU2ht_xu7TXoY_IeEj5b_Yk3-GAYN5o0Ek0hqeFmBa6i7AAvKzJnoLd3Zk2yQfVGhEIsDwrBhpt5gCNhy0f8PMTQhpnpmmJCu1qfBCStfQJjku1Mzhw=w1250-h937-no
ACtC-3cFCNbnv_G--1vmq6FQVWQBiWEUpAG2-3ZGKLNLyIs01_X33nxfqcfUKRpt-0edk4h32tMxETFhbp5IaZnd9t8BXsgbPpUNcvQU2Rx5BTtQKxh2V94EVBrRUi90uPGTb1RJGh-E7fl9Mpd0oQNryuLq=w1250-h937-no
It’s looking good!! Some quality parts there for sure
Thank you :D
Yeah, its had a good bunch of upgrades already "thumbsup"
Swapped out the remaining rod ends, and paired it to my MT-4s and took it for a testdrive. Worked awesome!
ACtC-3eeiEX91aIeRI38VKhEXDaKynJb3BkhZpZYd6DzftphjrsC38MzKt6ip5wesjSPFUP8-JxfVpVGA-F7aXkR-m3byuQXr70DRGL_61_cq5vM0TIOEYGSInrxPCNlmjG4ZgmT6lZXrhUsLtxzCUHmbvzY=w1250-h937-no
ACtC-3eAoyIdL88-phJ3JM3q-L2fCgRs2-5G5NVhlMicvobPjUalskJMLOL57S-uk5d6NF7PXAhI_dpIYIycjuUwWxwijopRfbEzVCuSs9smSN4TXo3BNEYL3pKMiwsCfrNXffnHlfSAS6EoPYFous_hY3GU=w1250-h937-no
Made a preliminary roof. Have some KrawlerKonzepts skins on the way
ACtC-3dy25hZDM0oV-0tVE2qY0l9Ba2hDQqmZfgVnGmPV7VIvgBWYjSa-Ch2fLS11NKM8tw-Mtw-ZhhBcjdZfS6wox4xZvLgR5XEs6_BTHXvEa94f29yiBWbzG--UrFkFrW3z5hAaN5xdmrU8Q-kZ6cRCZAc=w1250-h937-no
Swapped out the front springs with some Dlux springs and printed lower cups. Changed oil to 15wt. May need supersoft springs here, the compression is alot harder than rear
ACtC-3fndb4pzF_yQwx0kf9iorAqvRPeCimx08YbCU9pGoGE7AIlwOnzYsJwpmpa5VGdWYPykXYOtdcmbq_DEdbDfMoFrFho6nEV7fsfftadCMKidJvV8qCtwt-cabVWCsJvOA-3sQuyTMjYWdKDAJGA_8HZ=w1250-h937-no
Clocked back the C hubs more, straigthened out the tie rod and got a good amount more of steering!
ACtC-3e_8XwjP23cgjxke01tqGFupD47Z8CgomIpzJh5AQkZLep5Go3Bhz8a_8uYWHBWyh9-T9RhmizU4crQxkCksGK2LkIfL88HlHj3D5aZBrwgIVpHdPj3uALWn6EsLwM8RYQaGl1uSpKtX7A8lGkswnCF=w703-h937-no
Made a set of Skinny Doovers. Made from 1.9 Red Dot Rovers with Voodoo Pin sidewall from some worn out pins.
My first cut'n'shut tires other than narrowing VooDoo's :)
ACtC-3ffVQ7Ry3wuEOCLXAQWwjc4NiueB3tn1zQU42UeU-8XdzfStNdAK2HyQlGhXZ2miG6hEpwxZWSNthI_miv-nlJ6TvfEB29WvnCsOZCnk8Sd-cLwy-NLsaD7xlBkSBC4lNW67rXS2Oxuq3HxPClm0TnR=w1250-h937-no
ACtC-3cYrBQH_1iGGAePKDpbuZ3OVSChV_dnrLKc7gs6_zXoZZ1OKBFny1PaoOZzzJZupMC_zdw0y04rfaUOdAxum-HNjO1PqXdOQGpIJV_FGzBF1Vec9T52qynTljTyYa1TeRgdQ8M_ms0ksVa63Gecablw=w1250-h937-no
ACtC-3fTiiJqyb5asOBVN0xvGM36deZw0ipzMkzy9VUDEQJsvOyAAZe7r9OY7aLIcj7YDqFAZJ2SYX4ionDeD_69KHP-NV7Kc-JGhJtQ6AZvCJYw1FGsCDdaayxHA7f6DV2dQJNQU_hVO4Wp7emusQekfnWC=w1250-h937-no
ACtC-3eOA44Wd84i8LnAYCG7-IhyWQT1YDofiM8y2zUa--B8ST6T7VkobXe-RYaovqbV5ZfUBi1X8XI9Xhp89PipIrZULK6_h576ODaQ3xOLYz2XYppGxBEQGmf-X3RIHR77DWomNvSZTcPh3D1GQCicC2xw=w1250-h937-no
ACtC-3dZreTWxkCwJzti6pY6qyEAYXeiQD6GMFF05TMgomfumjzFZrPG57CPLiccf-p0XRLSrA3xUyM3xOO6IADZiKFZpqUy1vqykHksEtfTS1gY3aDtxztwu3geKy0a-VqAz7zXYUqZz0g6NrreNDOshcoN=w1250-h937-no
ACtC-3cLjzl3FUYxkUQaAQ2HSXA8A2a95WJZsXXQTdTmKhuVimZRSfJMOTYbhs_Oy5oIjzIpksjP7-KM2r2ZplrUXnTCTl14g-keLdUSiAY4-Z-GZPN_pQbXX-Ehgm-u63UMkh1FwXNPlEtPHwHguqo3VouC=w1250-h937-no
Swapped out that worn out Bluebird servo for a Futaba CB700 :mrgreen:
ACtC-3cN-DHilWkNCAPSPlsIq2E7wEIZQa_z7HjPJNZiyq37kIxv300AGT02Y-q4pTj5Qb_4enzIiH98p59UeItrOjFF4I6jMw00I9NE34XV704PpBKdmvmzvRHhJ5xZ6q1hkFTjSliQ59LLIAigTGmdy8O_=w1250-h937-no
