OSRC
Another spare parts build from my junk-o-rama....
I saw this on Roadkill the other day and thought it was the coolest thing they came up with to date. If you've never seen the show, it's a rotted out C4 Vette that they stripped to the chassis, added a roll cage and went out and hammered it around a track (and in the dirt) - looked like a ton of fun! Since I can't build a real one, I can be at least inspired to make a small one.
2200lbs of C4 goodness
Video link...make sure the surround sound is on: https://www.youtube.com/watch?v=GD3y7ylpqO8&t=4s
I'll be taking a few liberties with the RC version of course. Not really looking to build a scale replica, just stealing the general concept. So I had this Yeti body laying here, and a pile of HPI MT/RS4 parts. Hence the HPyetI (see what I did there?
HPI MT's and RS43's are great to mess with - Axial diffs drop right in, so I can use pretty much any trans with 5mm outputs and connect them together..or dogbones, or any combination thereof. I can drop in OD, UD, 1-ways, spools...pretty much any combo I can think of. Plus, there are 4 different width suspension arms that bolt up so the track width is very flexible too. It's a great platform to mess with.
Anyway, so I started with the MT chassis as a template and stretched it out 35mm and widened it quite a bit to give plenty of room for a battery and what not. It's just rough cut at the moment, I'll fine tune it later.
Drilled a few holes, clearanced the diffs and dropped on the suspension. I've got MT2 arms on here which are the widest of the bunch. Not sure if I want a wider track or something more scale (ish) - I'll sort that out later. Diffs are HD gears standard ratio front and rear for now. The front is a limited slip setup.
Dropped the body on... Very much a work in progress! At least the wheelbase is now roughly in the ballpark.
I've got to sort out the shock towers.. the front just tucks in, but the rear is way tall and interferes with the cage work. I've got a few options to mess with here thankfully. Should be too hard to custom fab up something if I have to. Whether it'll be square or not is a whole other matter.
Not much to see yet. ...but more hot mess to come. "thumbsup"
