Tire foams for 1.9 PB RB xl
Jeep757
Hampton Roads
Which foams would be good from crawler innovations for these tires. Uses would be trail/beach/crawling/hill climbs.
Thank you
I tried all of the crawler innovation foams and none fit. The foams that come with the tires work best
I have method 105 wheels and 4.75 crawler innovation foams soft fronts and medium rear, I have a lot space between the tire and foam, tires fold over when side hilling which causes easy rollover.
What didn't you like about the stock foam? If you feel it is too firm or tall, they do break in a bit. I currently run 4.75 with soft outers and love the setup, however they dont fill the tires. I wouldn't recommend them for trail use. My truck is low light 11.5 wb. I did try proline dual stages I had on hand, and they filled the tire well...
I do like the stock foams over the crawler innovation foams because they are more predictable.
After the stock foams broke in a bit I found them to be pretty good for general trail and crawling use."thumbsup"
The stock foams are pretty stiff. On a heavy truck they would probably do pretty well once broken in, but when they are new they did not do very well for me. They couldn't hang with my TSL XLs (that had CI foams).
The best foams I have used in mine are 4.75 comp cut CI Lil Novas. Depending on weight of your rig, either soft front and medium rear or medium front and firm rear. Non comp cut 4.75s work well too, but for a tire with fairly large lug spacing I prefer a bit more give, hence the comp cut.
Its a pretty stock rig so the soft/med would probably be good.
Alum links, hence cms/battery relocation plate are the only added weight items.
