BOWTIE
Ultimate RC Decals
looking good tommy!!!
would like to see it on the 25th.
Thanks, Ric.I sure hope to have it done by then! Ideally, it'll be competing. If it's not done, I'll still bring it out anyway....
Thanks for the good words. 8) It is hard to understand the work involved until you try to build something completely custom. Trying to plan for just the right clearances, fit, and look.Thanks, Chris! Yeah, I think it'll be fine. I gotta tell ya, I have so much MORE respect for the likes of you and Tim and your abilities after undertaking this build. So many things to consider, so many unforeseen challenges, and so much time required. My Jeep pales in comparison to the amount of work I've put into this thing so far....and it's maybe 1/2 done?? :lmao:
Same issue I had with Guido before and it got worse when I pushed the axle forward. I was able to trim away the outer part of the grill and put in smaller light buckets. Similar to your idea #2. I got the idea from JR's 1:1 Bronco.I've got a bit of a dilemma on the front end, however. The front tires are all up into the grill. Here the truck is at ride height with NO added weight at full lock. The tire is already into the grill. At full stuff it lifts the body a good 1/2" or so. In other words, quite a bit of interference...
I think I've got three options on how to deal with this.
1. Move the headlights closer to the center and trim the lexan to allow the tire some clearance. This may look a little odd.
2. Do away with the front headlights and trim as needed. Maybe add light buckets to the front bumper or something.
3. Dovetail it. Not sure I could pull it off cleanly and without the rear being doved, it may look odd.
Thoughts?
It's not doved in that picture, I doved it for the rebuild I'm doing now. Just wanted to clarify.Thanks, Chris... I didn't realize Guido was doved up front. You must've done a good job on it!![]()
Nice job on setting up the suspension and steering. I love the perfect fit of the drag link between the frame and the leaf spring. "thumbsup"
not only is your jeep awesome but your scalers are too. im jealous
BTW its AlTheKiller from JF
Awesome thanks for the link!
cant say ill run my junk in it but im definitely going to check it out and probably bring my photo gear "thumbsup"
