Topher builds a class 2 comp rig - Crawl Space Game Changer 4.2
Quick update and a few pics. These axles have now been repurposed and are being used on the GSpeed v3 build. Instead, I’m going to break down the trail king and put those axles, shocks, and electronics on this rig.
I did get new 40mm screws so I can get back to building on this one once I tear down the trail king. In the meantime here are a few pics to share.
First pic shows the panhard mount. With so many mounting locations getting proper axle swing here shouldn’t be a problem. The aluminum feels nice and sturdy as well.
Also added a pic of the goods, the compact and nicely overdriven t case and front motor mount are simple but well designed. Nice angles for the top shaft and plenty of room for the motor.
I’m interested to see more of this build. I built my game changer chassis a while ago and then gave up. But now I ordered some crawlspace sliders for it, put capra axles under it with CMS and now have motivation to finish it. I was debating on putting 10.3 axles but would require flipping the transmission and figuring out how to do the transfer case since you cant flip it because the angle.
That sounds like a cool build! Hope you pick it back up and share it in action.
Its looking good, I’m sure the aluminum is stronger than the G10 that i have. I guess I should get some pictures and start a thread on mine, i got my sliders today, and ordered the trans and transfer case flip kit housings. I think it will be better weight balanced side to side with the motor opposite of the servo since I’m not going to run a winch. And also the option to run the 10.3 axles easily. You can buy the AR45 housings and shafts and just swap all the capra parts into them. The universals are the most expensive part. I’m going to keep plastic axles to save weight for now, actually trying to keep a rig light is hard, all my other rigs have metal axles and end up 8 pounds without trying.
Oh...wait...ok! Now I see what your doing! I forgot about this rig your building also!
Man, two bad a$$ rigs at the same time! You really do mean business!8)
I'll be following both of them!"thumbsup"
Looking good man! Definitely inspired me to move forward with my comp chassis. Can't wait to check out your running vids.
Back to work on this one. I grabbed some traxxas screws (TRA2592) and was back underway. Used a power driver this time and greased the threads and had no issues.
Got the links built up and almost ready to put some axles under it.
Been a lot of building around here! But when this one is finished, and a refresh on the vs410 is finished (new body, diff wb), I’ll be done building for a while and back to wheeling.
Thanks Walsh! I’m excited to run it. Glad to see you’re working on your comp chassis too "thumbsup"
Everything was going together smoothly until I stripped one of the 40mm screws going into the skid plate. I could feel another one starting to round out so I stopped there.
I had this exact issue when I was building one for someone. Replaced the screws and didn't have any problems. I think the included M3x40 screws are low quality.
Axles and suspension are mounted up but the build is unfortunately stalled as the servo I ordered was dead on arrival. Having a heck of a time with the eBay seller too so I’m not sure how quickly I’ll get a replacement. May take the servo out of the vs410 in the meantime as that one is waiting on some body work.
Anyway, here are pics with axles and suspension. The trail king axles worked well enough, I had to space the upper link over to the outside of the mounting points on the pumpkin. There’s clearance until just before full compression where the driveshaft starts to hit the motor mount. It may not be a problem in the wild.
I could shave the motor mount a bit and clear it up, or I may get a center pumpkin axle for the front. Another option is these tubes and flip the pumpkin to the other side. Either way I’ll have to get new chubs and shock/link mounts so I’m on the fence about which way to go.
https://www.amainhobbies.com/ssd-rc-scx10-ii-pro44-aluminum-offset-front-tubes-ssd00398/p1155901?r=0
I’m starting to not be a fan of much stainless steel hardware in general, I think the hardware they include is from KNK so I’d expect it to not be awful. But stainless being soft in general maybe isn’t the best idea for a screw with so much thread.
I'd flip the pumpkin.
I'm not sure where the hardware came from, but I had other stainless M3x40 screws that I put in and had no problems. But I would agree black oxide, especially in a skid application is a better option.
In an effort to not have to buy more parts, I swapped axle tubes and whatnot with my Scx10ii and now have an offset front on the 10.2 JK and the standard center pumpkin on here. Full clearance and no issues anywhere now.
Finally got the refund from the eBay seller but I still don’t have a servo. JRH had mentioned v3s should be coming back in stock within a couple weeks so trying to hold tight for one of those.
As far as the body goes, I’m not sure. I have a 4runner on hand that I’ll probably start with but that may change as always. I think I’ll get that going this week and get some wheels and tires on it.
Made some more progress on this one and it’s almost ready to run. I painted up a 4runner body for this one and went with a BMow inspired paint scheme. Pretty happy with the outcome. Might slap a couple HH decals on once I get the electronics done.
Last night I mounted the mamba x and the receiver, also switched from the castle 2280 slate to a puller pro stubby 2700kv. All that’s left to do now is get the battery mounting figured out and then steal a servo from something.
Looking real good mate!..
I love these chassis types.
Thanks Stimpy! "thumbsup"
Man, this build looks awesome!"thumbsup"
Nice choice on the colors! I approve!;-) Body turned out great! Just be careful not to scratch it! Yeah, right! Can't wait to see this beauty out on the rocks!
Looking good! My batteries fit on the skid next to the t-case nicely, and I really like that location. I designed and printed a mounting plate that bolts to the skid with the existing holes, but lexan and some spacers would work just as well. I have the plate elevated slightly off the skid so that the suspension links don't hit the battery and to allow a velcro strap to be used.
It was the head of the screw. Got it out without much effort and have some replacements on the way.
Suspect it's the hardware they supply as I did the same on one of mine. Look forward to seeing this beast of yours completed.
My rolling chassis has been sitting with some provisional links from Samix whilst I await the arrival of my hardcore links. Seeing your build has me all excited again about getting mine done. Unfortunately mine loses some of the low cg benefits as I am putting it on portals as those are the only axles I have spare sitting around and can't bring myself to spend on new axles currently.
Thanks y’all! I appreciate it.
I got the battery situated by using one of my favorite tools and shoe-goo’d a trimmed up element enduro battery tray to the slider. Ran it under its own power for the first time and started bench testing. Seems ready for the rocks, I won’t be able to wheel this weekend so I’m shooting for a maiden voyage the following week.
While bored yesterday I also played around with some automotive pin striping. The lines/stripes clash so I’m taking them off but figured I’d say a pic in case any of you are curious to what it looks like for your own purposes.
<blockquote class="instagram-media" data-instgrm-permalink="https://www.instagram.com/p/CA-32iBgRrV/?utm_source=ig_embed&utm_campaign=loading" data-instgrm-version="12" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/CA-32iBgRrV/?utm_source=ig_embed&utm_campaign=loading" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center; margin-bottom: 24px;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 224px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 144px;"></div></div></a><p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;"><a href="https://www.instagram.com/p/CA-32iBgRrV/?utm_source=ig_embed&utm_campaign=loading" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none;" target="_blank">A post shared by topher Builds (@topherbuilds)</a> on <time style=" font-family:Arial,sans-serif; font-size:14px; line-height:17px;" datetime="2020-06-03T18:10:10+00:00">Jun 3, 2020 at 11:10am PDT</time></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
Thanks! That’s cool it got you excited for your own project. Bummer about the hardware though.
Thanks! That servo doesn’t look too bad, wish it was in the states though. I’m moving next month and don’t want to risk waiting for anything from China, and am also still trying to sit tight for the HHV3.
For now I stole the protek servo out of my scx10.3
Looks damn good bro! How do you like this compared to the GSPEED? What side plates did you use?
Lou
