Mechanicalbob
Well after reading most of this thread I decided to put in my $.02 on this servo. I have had a few before and I also recieved a few from Double J and I like them they are a good platform to work off of. Just like any product there are bad ones that go through, just some companys check all of them and toss the bad ones, and other company dont. One thing I have found with these is the POT goes bad on them and that is what can cause some glitching. The POT is alway trying to find a zero spot or correcting for a ummmm a ummmm aaaa, I forgot I have to go back to the books. They are not hard to change out or put in some resestors for constant turn. I have found a replacement for them at radio shack for 2 bucks for 4 of them. Just use care when soldering the wires in place as heat will kill the POT. Also the electrical board is not protected from stuff in the case and this causes it to short out sometimes. To help with this I use some liquid electrical tape on it and it also water proofs it as well. Also some Hi-Tec servos use the same type of setup and I have just swapped the electrical stuff out. I will have to find the servo model.
Here is an example of what to do with one, this one is new and has no probilms (Thanks DJ"thumbsup" ) just showing the basics.
First remove the 4 screws at the bottom and remove the top and bottom plates. Then use a small flat blade screwdrive to gently pry the POT gear off (the one with the bearing)
To get out the POT remove the philips screw inside the case, then push lightly on the shaft.
Then the POT is out. If you are replacing it you can cut the wires at the POT or de-solder them. Then re-solder the new POT in place and cover with liquid electrical tape.
