Lentsnh2012
I'm not trying to compare to the Scx10 we all know it can out perform the tf2. But if you're going to zone in on the yota body with ar60sa under it. What's the difference between the scx10 with the yota body and ar60s, verse the tf2 with the yota body and ar60s. The scx10 looks good, but the tf2 with the same body and axles won't?
A real truck doesn't have the suspension setup as the scx10. So putting full widths under the tf2 would be more scale, than the scx10 with full widths.
The SCX10 can handle 2.2 series tires and AR60 axles... The stock TF2 components probably wont.
The SCX10 [Honcho] has a wider cab than the TF2 does. That's why you see more people do the Wroncho conversion. Because it looks more natural.
A real 1:1 truck doesn't have the same suspension setup as a SCX10..... :roll: Have you ever heard of 3 link with panhard or 4 link (radius arms) and coilovers? How do you think Axial and other brands got the inspiration for their own products? Because the 1:1 world had links and radius arms.
The 4 link with the servo on the axle is the same concept as what the KOH buggies and Rockbouncer buggies have, except they use a double ended hydro ram to steer.
