I run aftermarket shock mounts that let you run 0, +5, or +10 mm on the upper shock mount. This will drop the truck accordingly, however, the front axle and linkages will start hitting stuff if you go this route and dont run a longer shock as well(IE longer shock body will keep the same bottom-out point). You could run 100mm shocks at the +5 and 110's at the +10 and still have the same bottom out point.
My goal was to try and run 110mm shocks(vs the stock 90's) but retain the factory ride height. I got there and the truck had an insane amount of flex, which was mostly down, as the up stopped at the same point as stock. Later I went back and put the stock shocks back on but at the +5 setting and I was hitting things on the front suspension and it was limiting uptravel.
The rear is less of an issue unless you run a low COG battery tray like the Bowhouse. In that case I was fine on the side to side flex/travel, but the straight up-n-down travel would cause the links to hit the tray.
