TTC entry thread
What has four wheels, flames, and goes like hell ... ?
Please consider this entry from the great Commonwealth of Kentucky; inspired by the nut-job's of the Pacific North West, this Kentucky-Fried Scrambler rocks hard, and never leaves from the bar alone.
My first TTC was 1996, when Heath Biggs brought his Scorpion MK1 (aka the anti-squat king from hell) and cleaned shop. I've been fascinated with the sport ever since and eventually got into RC Crawling in part because of my interest in the 1:1 world. I'm flying 2300 miles to have a good time, meet some great guys, and to show the world what the Super Scrambler can do. "thumbsup"
Axles:
-Vanquish Products AX-10 Aluminum axles cases
-Vanquish Products AX-10 Aluminum axle trusses
-Vanquish Products AX-10 Aluminum Servo Mount (moved back 6mm to correct steering geometry)
-Vanquish Products AX-10 8* C-hubs
-Vanquish Products AX-10 8* Knuckles
-Vanquish Products Wraith Differential Cover
-Vanquish Products 1/4" Titanium steering links
-STRC Aluminum lower link mounts
-STRC Aluminum Bearing retainers
-DLUX No Slop knuckle bushings
-Axial HD Wraith R/P, (overdrive front, stock ratio rear)
-SDS 300m Super 300 CVD's, Lockers, HD Pins
-Boca Green Seal Bearings
-Gunnar hex pins
-RCP Crawlers aluminum TLT hexes
-18-8 Stainless hardware throughout
Electronics:
Motor: Tekin Pro4 3300 Kv
Speed Control: Castle Creations MMP
Batteries: 4 Cell Thunder Power 65C - 14.8v
Front / Rear Steering: Hitec 7950th @ 7.4v
Winch Servo: Hitec 7995tg @11.1v
Winch Controller: Heyok 16amp relay controller
RX/TX: Futaba 4Pl
Transmission and drivelines:
-HR Aluminum Case
-HR Heavy duty motor mount
-HR Hardened steel gears
-HR Aluminum spur gear adapter
-56t 32p Spur gear
-12t 32p Pinion
-MIP AX-10 driveshafts, wraith axle outputs, drilled and taped for extra sets screws around pin
Chassis and Suspension:
-Custom CJ8 Chassis built by MG200 Designs
-Pro-Line CJ8 body, paint by Jwalker
-Vanquish Products 1/4" Titanium links
-HR Aluminum / Derlin SCX-10 skid
-Pro-line Power stroke shocks
-Custom Scale interior and drop bed
Wheels / Tires:
-CAC Sinner II's with center caps, stainless hardware
-5/8" CAC hubs
-Crawler Innovations DD Foams
-Pitbull tires
Man, I hope that gets voted in. I love KFC after an event.:mrgreen:
Its only fitting we remove that clear coat from the body.
This is shaping up to be a great one! Anybody that has updated pictures, be sure to add them to your entry thread. I'll be taking the best single picture from that thread for the TTC vote thread. Also include at least your first name in your entry thread just in case I don't know it. Thanks, Tim.
You have 16 hours and 10 minutes to submit your entry.
Most of you know who I am, for the newer guys to the Hobby- This is last years MSD TTC Champion. The scores from last year showed that this truck has what it takes to dominate the competition.
Hence this truck has been named "The Ripper"
As you can see comes equiped with its own "Reaper" to help eliminate the competition.
Outside of the new paint this truck has undergone a major CG drop, to further improve the handling.
Electronics:
Tekin RS Pro-driving a Hiperion 13.5 sensored brushless motor
CC Bec's
Tekin B1R-Feeding front and rear winches
Power Source-After running on 6s, 4s has proven to be more then enough power and allows for a better balance in the truck with a smaller battery.
Winch Duties- There is only one way to accomplish winching in these type of trucks
Front-QS-8274 on 4s
Rear-QS-8274 on 4s
The Ripper is still utilizing my stacks t-case that has been regeared and direct driven to eliminate the driveshaft failures that caused me to have to go a little easy on the truck last year.
To help with the depth of mud and water this year I upsized to 5.75 TSL's!! You can never have to much tire
I have a little more tube work to finish up though an injury has slowed my progress this year(of course a little procrastination earlier in the year didnt help either), though I may have it finished and update pics by the end of the day.
If I get voted in to the event this year I will put up 250.00 to the winner. Though I plan on defending my title. Good luck to all that have entered, I hope to be competing with some of the best trucks around at this Years NWSC TTC!!!!
Thanks in advance if you consider voting for me!!
Ladies and Gentlemen I give you for your voting pleasure......
Cole's Crawlmaro
Crawlmaro had a blast at the 2012 AxialFest 1000 +/- gate G6. And I'm proud to say we finished all 3 stages. Learning a lot from some of the top rc drivers, Crawlmaro wants to run with the best drivers and trucks in the rc world.
Now transformed into TTC ready with 5.75" Iroks and the all new rc4wd KING shocks. And if I am voted in I will personally guarantee to put on a show because I'm about the WOW factor!
Here's a link to my page bit.ly/rccrawlmaro
And the list
pro4 3300
MMP
Savox sc1268 steering servo
Hitec 645 servo winch
CC BEC
Dx3c
4s
Customized Wraith Chassis
Custom Dash, Rear Trunk Panel, Inner fenderwells
2010 Chevy Camaro Body
Vp Links All Around
MG200 Servo Winch Mount
AR60 Axles
Vp Chubs, Knuckles
Vp Rear Lockouts
Vp Diff Covers
Vp Racing Ackermann Steering Links
HD F/R Ring and Pinion
HR Lockers
Strc Locker Caps
Axial Universals (front, from wraith kit)
RR Tranny Gears
32p spur & pinion
MIP Drive shafts
2.2 Mayhem Eng. Monster EX Beadlock Wheels
2.2 RC4WD Irok Tires
RC4WD KING OFFROAD Shocks
RC4WD Warn Hubs
Team3six seatbelts
Thank you to all that vote for me in advance and it would be both my and Crawlmaro's honor to NOT disappoint in the 2012 NWSC TTC!
BuBs 4Runner
Build Thread:
http://www.rccrawler.com/forum/2-2-scale-rigs/391766-bubs-ttc-4runner.html
Chassis:
Scx10 Frame with wraith skid and tube chassis. 3/16
Drivetrain:
Built wraith trans stuffed with steel gears.
Mip drive shafts
Tekin pro4 3300
MMP
Axles and suspension:
Built AR60's
Axial unis front and rear
3 link with panhard in the front
Triangulated 4 ling in the rear
Links are 1/4 o.d .049 wall aluminum tube with Revo rod ends
Shocks are SCX10 shocks mixed with RC$WD scale shocks.
SCX10 skid
Electronics:
2 Castle bec's
2 hobico cs-170 Front and rear steer.
2 hitech 645mg wicn servos, front and rear
Wheels and Tires:
VP wheels with 2.2 Super Swampers and CI foams
The Body:
RC4WD T-Runner lexan body narrowed 2 inches. Painted same Toyota red as the 1.1
Full interior metal tube cage. Painted flat black.
http://s42.photobucket.com/albums/e307/chevelles6571/?action=view&current=MyMovie.mp4
I just got this thing going. It was built just for TTC. I want to see how it does against the best. Give it a chance you wont be disappointed.
57 chevy
proline 57 chev PU body
axial scx10 chassis
built wraith axles
RR geared trans
35t brood or more ?
mamba max
cs170 servo
servo winch
waith interior
wheelinjp tube work
rc4wd wheels
2.2 tls sx's or pitbull
I'm still finishing the truck so not sure of all the final details
40 minutes guys.
Any entries after 12:00 am will not count. I'm going to bed and I have a scale comp tomorrow, so I'm not going to get the voting thread open until tomorrow night. Thanks for all the entries, this is going to be a close vote for sure! The 12 trucks with the most votes will be invited to compete. We will have alternates in case someone doesn't show, so don't be too sad if you finish 13th or 14th in voting.......we had two alternates compete at last years MSD TTC.
More info tomorrow night! Thanks, Tim.
Here is my wraith, not nearly as custom as most on here but I figured why not give it shot.
Chassis: Stock with numerous revisions
Axles: VP aluminum nut to nut
Overdrive gears in front
Hot racing lockers, at the moment
VP cvds in the mail
Rear steer
Tranny: VP aluminum
Super shafty top shaft with slash steel RR slipper
RR steel gears
CI chromo outputs
MIP drive shafts
Electronics: 3300 kv Pro 4
Tekin RX8 esc
4pl radio
Savox 1230 servos for steering front and rear
Solar 772 servo winches with TZI controllers
2x castle BEC
3S power from 2x1300mah lipos
Wheels Tires: VP slw 6? and R35 ripsaws
Suspension:Gmade xd bypass shocks
VP ti links
Wow, thats about all I can think about. I was in TTC in 06 with the red 66 ford. I really want to build that rig but time ran out. Thanks for your consideration.
Hey Tim, what happened to page 3. I shared the link with our Wa. club yesterday and it was up, today nada.......................................:cry:
I have 3 pages.... "thumbsup"
Nope, SDS Customz, Bubs, Mud digger, runs 2 jeepin and Sam 63 were on page 3. If I remember correctly this happened last year or the year before as well (hopefully it's just my computer skills, but I just rebooted my computer and still only two pages
Page 3? I have had only 2 pages for a week now.
I see all of them on my screen.
Last year was entirely domething else that effected the whole website. Badger spent hours restoring it so nothing was lost except for an hour.
My settings are set up so I have more posts per screen and that is my computer or iphone.
