This is my 2nd go at the twin hammers. I thought I figured out all the tricks. But two issues persist. Maybe you guys know some things I don't.
Configuration;
Stock battery and ESC
Stock tires
Stock gearing
Traxxas 12T 550 brushed
Issue 1: Steering
I threw on the Irie bellcrank plate and shock tower expecting this to remedy the shot steering. But, I still have issues with it pulling a little left or right.
I adjusted tie rods and transmitter settings. But it will still pull a lil left and then after some driving switch to a right pull, for instance.
There is a little bit of play in bellcrank assembly. Maybe needs to be tightened.
Stock servo, horn and linkage. I mounted linkage to rear of horn and the other end of linkage goes to top of bellcrank arm. It rubs the plate a tiny bit, but seems to move freely.
The screws that mount the tie rods were a bit long and rubbing plate, so I put washers under tie rod to pull them away.
Do I need to toe in my tires? I'm aiming for straight on.
Is this caused by my rear locker?
Crappy stock servo not resetting to zero?
Issue 2: Sway
I'm running stock rear shocks and in front I have some cheap shocks until my gmade 85xd show up.
Heaviest swaybar front and rear.
When I had the cantilever shocks up front it was tighter, so I know my cheap front shocks are soft. These are causing me to lift a front tire under acceleration even with sway bars!
But even before the shock switch, I was still getting a lot of lean in back.
I'm guessing it's just the flexy rear geometry.
I'm gonna try the GCM rear link mount. But after that what can I do?
I guess I could mount the shocks upright more?
Make a sway bar that actually goes to the axle tube.
Or I could run heavier spring or shock weight. But, I want this thing to have usable simple suspension with no sway.
I really appreciate your ideas.
Configuration;
Stock tires
Stock gearing
Issue 1: Steering
Issue 2: Sway
