bastard
- Joined
- Jan 22, 2004
- Messages
- 708
Ok txt-1 stock ratio is 34 to 1. What would it be with an eight tooth pinion? I figured it to be 60 to 1. But i don't know if that is right.
I need to figure out what it is so I can figure out what ratio to use in the new crawler. The plan is to use a mag mayham to a 3.8 to 1 planitary With a 8 tooth pinion to a 72 tooth spur gear to txt-1 axles which are 2 to 1. The curant ratio is good but the new crawler will have some skinny kongs (thank for the idea dirk) so I need to get some lower gearing.
