ussprinceton2004
I have the new Traxxas 2012 Platinum Edition LCG 4X4 Slash. I will be mounting the TenShock SC411 3500kv motor and HobbyWing SCT Pro 120A esc combo from the funshobby website. I will be using 3S 5000mAh LiPo batteries. I need to know what gearing I should have. I am not looking to get top high speeds. Rather, I want fast acceleration instead.
I will be purchasing Robinson Racing Extra Hard .8 module 5mm bore pinions. What is the lowest number of teeth 32p pinion should I use. In the same note, what is the highest number of teeth 32p pinion should I use. Keep in mind, I'll be running 3S with the SC411 3500kv motor. I want to keep the temperatures as low as possible. Like I said, I don't want top high speeds, but I do want faster acceleration.
In the same subject, what number of teeth 32p spur gear should I use. I don't mind buying several 32p pinion and spur gears with different number of teeth. But, I don't want to purchase something that I won't be using, like really low or really high number of teeth.
All answers would be greatly appreciated.
