what size nut drivers
vito
roseburg
dose the kit come with them and what size i got a mip tool kit for it to 1.5 2.0 and 2.5 mm?
For this kit you will need 1.5, 2.0, 2.5 and 3.0mm hex drivers. The kit comes with some basic L type alen wrenches but I couldn't imagine trying to build this thing with those.
what size drivers in the book i see 4 and 3 is in mm in sizes a main dint see a 4 or 3 driver in tools
Vito, you see the thread size in 4mm and 3mm. What they dont show you is what size each screw driver is used for each screw. If you look in your manual on page 3, it will show you the required tools. This however is not entirely accurate. As mentioned above, you will need a 1.5, 2, 2.5 and 3mm hex drivers for this kit. If you have the MIP tool kit as you stated above, all you will need is a 3mm allen wrench for the 2 motor mount strap screws.
The only tools that come in this kit are the standard Tamiya wrench and the large 4 way wrench - much like these:
Amazon.com: Magnum Long Reach 4-Way RC Glow Plug Wrench: Toys & Games
http://www.hobbyease.com/small-4-way-wrench-4mm-5mm-5-5mm-7mm-p2267.html
