Wheel (offset) question in regards to the Pajero body
andymac0035
Canaan
I have a Pajero Rally headed my way. 8)
Wanting to use axial bead locks if possible. (have the low profile kingpins ordered too, so I got that part covered)
I went with the Pajero as I know it's supposed to be on the wide side for CC-01's and went with the Rally, as I wanted a lexan body to save weight up high, as I intend to trail and crawl with this a LOT.
I cannot seem to find any specs on Pajero body width. I can find width of the assembled kit, but that does not tell me if its tire-to-tire or body (I suspect it's tire-to-tire)... and also some of the #'s I have found are conflicting.
I used to have the CC-01 Bronco, and I know for that one, I needed positive offset wheels to keep the tires inside the fenders. I'm pretty sure the Pajero body is wider than the Bronco body, but again, I can't seem to find specs anywhere.
I do have some G-made bead locks with 2mm positive offset, but they are white, and I was thinking of painting the pajero Silver.... which I don't think would match up well. If I went with the white wheels I'd probably paint the body red instead.... and I'm trying to decide what color paint to buy... so you get the idea of where I'm at now.
The Bronco body is 185mm in front and 190mm rear, at the upper fender flair.
I'm pretty sure the Pajero rims are 4mm offset.
I Googled the other bodies for ya, and the Rally/Low-rider body is 190mm and the hard body is 195mm.
Here are some pics so you can see the differences.
"thumbsup""thumbsup"
The lexan Pajero body is exactly 190mm at the widest point of the fenders, both front and rear. The Bronco is 190mm out back and 185 up front. (Just happen to have both bodies laying here in my hoard)
The stock wheels are 5mm offset IIRC. Anything less should help tuck in a little better.
Thank you both for the replies! I meant to post-back sooner but have been a bit distracted lately. I still don't have my Pajero yet. It's been sitting in limbo since about March 28th and it's getting pretty annoying. I've considered buying one that was in the country.... but there aren't any..... LOL
It's annoying too, because a few weeks ago I could have gotten a landfreeder off ebay and if it was still available... I'd have ordered it over the weekend.
I just have to be patient I guess. It helps that I have 3 other crawlers and winter's snow and ice have finally loosened their grip on the trails.
