Wheels help!! Cepek Torque ?
SkyJacked
L-Town
I just got a set of dick cepek torque wheels. I put them on my rtr scx10 jk. The axle shafts stick out through the center of the wheel to far to install center caps. Anyone else have this problem or have a fix for it ?
Just keep the center caps off. They are pain to remove and put back on when you take your wheels off.
Ive had that happen...just use a cut off wheel and trim your axle stubs.
2wd gray front traxxas hexs work perfect
Both of these ideas will work. If you decide to shorten the axle be sure you measure twice and cut once. You don't want to cut off too much.
The gray Traxxas hexes are off a Slash, Pep boy's auto parts carries Traxxas part and should have them in stock. At least my Pep boy's has them, I just picked up a set last Friday.
Good luck."thumbsup"
