  • RCSC
wheely king axle
TWEAK
does any make a wider straight axle kit for the wheely king axle???need help building a really wide trophy truck any help would be great
x2 on the wideners, or you can try to dig up some wheels with a big offset. Not alot of choices there.
Keep in mind that the further you push the wheels out, the more stress you put on the axle and its parts.
You could build your own axles too.
any how too"s on building a axle i need it to be strong the truck is going to be on the heavy side
You might search around on the Maxx section, lots of us built our own axles around T-Maxx diffs.
I'd explain how I did mine, but they wouldn't hold up to trophy truck antics..."thumbsup"
why not just go with a positive offset wheel?
Why not just use a twin force axle? If you want the beef and the width, you'll be hard pressed to do better. You can basically set them to any width you want, and they're beefy as hell. That's what I'd do.
Or you check out Mnster's thread on cheap lock outs for WK axles, and if you have access to a welder then you can make them as wide as you want, just lengthen the shafts and make your lock outs longer.
