That looks like a good fit, is that lexan? Is that the New Bright body?
Drop that body down and make it a lowrider Monster truck!
I'm thinking about ways to lighten up the Toyota body. I may cut the bed and just leave the bed sides or "Truggie" it and 3d print a back cage. I think I may get another just to put this body on, I've had it in my cart for 3 days already lol
That looks like a good fit...
Very nice....again. What filament are you printing with? Nozzle worn out? Calibration, keeping filament warm and dry (hygroscopic, absorbs moisture to some extent), printer located in warm/dry area can all affect print output.
Proper to clean oil residue off dogbones before final Loctite job.
Holes to mount factory LEDs in the bumper would be good imo, need some red led rocklights and maybe a pair of much dimmer red taillights.
Here's some pictures of the slice attempt.Yeah you could copy and paste it into the other thread but its fine here too.
I just checked out the hinge and I'm not seeing anything getting cut off using Prusa Slicer.
This piece is really small which may have something to do with it, what sized nozzle did you use? I used a .15
To get my body to fit when lowered I did cut off some material below the grill, but I'm also using a different bumper too.
Is anyone else having trouble printing the hinge?
Hmmm. Anyone else using simplify3D?Hinge printed flawlessly on my CR-10S; used Cura, stock CR-10S.
Just picked me up 2. One for me and one for my daughter. Definitely going to print the battery mount and hinge. I would also like a no light version of the bumper when you get that file ready.
I've got a Dremel 3D printer at work. I'm still learning on the modeling parts. Thanks for all you research and freely sharing info.
You are the MAN thank you! Im going to give it try right nowNice I've got a 2nd on the way too, so fun these little guys!
Its my pleasure to share "thumbsup"
I can put that bumper up now, its good to go.
I did try to make a version with lights but the width just doesnt work out so I'd need to totally redesign it, so I'm probably not going to do a version with lights.
I went through my design process on the hinge and I think I found the cause, and its likely something I may have never caught without your feedback mathcanbefun (I think my software fixes it for me) so thanks "thumbsup".
So the extrusion was done as a "new body" instead of "join", I've switched it to join and I think that was likely the cause.
I pulled the original file out and added the new one
https://www.thingiverse.com/thing:3677918
EDIT: I just posted up the front bumper https://www.thingiverse.com/thing:3686020
I made sure I didnt make the same mistake that I made on the hinge, sure enough I did (fixed it though). From now on I'll be actively avoiding the new body option.
