saddlesore
i recently upgraded the rear with Axial's full width adapter. the intention was to have the same track width all around so i could have more wheel options. i installed a set of aluminum 12mm hexes now im just trying to find some wheels to slap on. i saw that proline had a set of 2.2 beadlocks and i wanted to give them a shot but i wanted to make sure they would work.
https://www.amainhobbies.com/prolin...awler-wheels-2-black-black-pro2757-15/p448460
my concern is that the proline front offset might interfere with the steering knuckle since the stock setup with the 6 bolt hub already has very little clearance. the proline wheel above will eliminate the need for the 6 bolt hub which will have the wheel closer to the steering knuckle.
anyone have any experience with this? will this work or do you have any other recommendations?
