TacoCrawler
I installed the RC4WD WARN winch...
am using their wireless controller
and I'm wanting to wire a power lead to the controller.
Thing is... I run dual 3s 2200mah LiPo's and their voltage exceeds RC4WD's
max voltage recommendation of 11.1v
so... possibly I need use a method that reduces that voltage
or use a separate battery altogether.
Can I wire the winch power + wire, splicing into my BEC's (7.4v) output
or "Y" out from the RX and plug the winch into that ?
^ or would the winch's draw cause a brown out to the RX/servo or worse simply fry it ?
I'm not super savvy with this electrical stuff.
Alternatively I have a small 2s 1300mah LiPo that I could use to power the winch separately...
but my chassis has limited space due to the dual 3s LiPo's.
So if using the 2s LiPo I would likely require that I mount it on the body's underside.
Which is not ideal as I will need plug in and unplug when the body were removed.
Is there a better method ?
Maybe a resistor of some value that would allow me to wire directly
into the ESC's power/battery connection, reducing the voltage of the 3s LiPo ?
I'd like to minimize the wiring and weight added.
thanks if you have the know "thumbsup"
