XTM X-Factor Electric Conversion
AK KRAWLER
North to Alaska - go north, the rush is on....
Well, this is going to be a long, drawn out build. Something my son and I can work on and build together.
Purchased some 5/16" Brass Rod and 4mm x 16mm socket head set screws and plan to build our own links to lengthen the wheelbase to around the specs of a Traxxas X-Max, so around 20".
Still totally undecided on a transmission or power plant at this point.
I have an old set of Jumbo Kongs to run, unless I come up with something different.
Any recommendations for the transmission and motor set-up?
I do not plan on this thing being fast at all, just for crawling around the yard and taking camping with us next year.
It was fun watching him go to town removing all the "nitro" associated parts.
Ordered the material to build the links today. SS Tubing, SS Threaded Rod and Losi Rod Ends.
Those parts should be in town by Jan 17th.
Was wanting to go pretty big with this, but having a hard time finding a body I like in the 18" to 20" wheelbase.
Any thoughts from the masses on where to find decent looking large scale bodies?
Alright, I have ordered a few parts for this and I fully suspect here will be changes along the way in regards to some of these items.
Chassis - X-Factor (or X-Factor 2, can't remember)
Axles - X-Factor
Links - Custom from 3/8" SS Tubing, SS 10-32 Threaded Rod and Losi Rod Ends (Ordered)
Wheelbase - Stretched to 18" - 20" (depending on what looks best with the body)
Tires - Imex Swamp Kongs (for now because I already have them)
Transmission - Summit 2-Speed (Ordered)
Drivelines - Custom of some sort, unsure yet
Motor - HobbyStar 4092 1480Kv (Ordered)
ESC - Mamba Monster X (Ordered)
Servo - JX Servo BLS-HV7146MG 46kg (For Now)
Receiver - Flysky FS-BS6 (will bind with my current GT5 Transmitter) (Ordered)
Body - Proline Gladiator (X-Maxx Size) (Ordered)
This will be something for just running around the yard and taking on camping trips.
No major speed runs, or really crazy crawling, just a fun build with my son.
One other thing to work out is the suspension. Whether to keep it cantilever or not.
So, I picked up a Holmes Puller Pro 3500Kv and Mamba Monster X ESC from a member here.
I'll probably use the Mamba on this build, but after speaking to Holmes, I'll be looking for a bigger, lower Kv motor.
Something more like the 1/8 Puller Pro 4274 1900Kv, not sure on the "Punchy" or "Smooth" yet.
Any other viable options out there that wont break the bank?
The $160 for the puller Pro is about my upper limit.
Thread in the Non-Crawler Section asking about motor choices.
Thread in the Electronics Section asking more specific questions about Kv Ratings.
Figured I’d post a little of the recent progress.
Built some simple C-Channel frame rails (straight for now), transmission mounts and the adapter from the chassis link mounts to the C-Channel frame rails.
It’s just a start and for mock up, but a few steps closer...
Made some progress over the last couple weeks.
I made the links using thick walled SS tubing, SS threaded rod and Traxxas rod ends, they turned out pretty nice, I still need to taper the the tube ends on the rear links to match the diameter of the rod ends.
Also, due to the length of the motor I used, I had to raise the transmission/motor assembly to make room for the rear upper links to articulate.
Body mock-up
Front links
Rear links
Transmission/motor mount lift
I am still deciding if I want to use the LST2 shocks, which will need much lighter springs and definitely a different shock mount, or ordering some other long, smaller diameter shocks and calling it good.
Any thoughts or suggestions.
Thanks in advance!
So, I ordered another set of shocks to see if I like them better than the LST2 shocks. The LST2 shocks are super stiff.
Shocks
If I don’t like them, I will either return them, or keep them for another project.
I am also considering cutting out new chassis plates to make the link mounts, frame rails and shock towers all one piece. Still up in the air on a lot of things.
Well, I received the Amazon RCAWD 140mm shocks I ordered. They look decent, but there is play between the lower pivot ball and the cup it sits in. That’s a no go for me. I’ll be returning them. They did however, have a little less spring pressure, which is what I’m after. They measured an even 5 lbs on the scale, where as the LST2 shocks measure between 5.8 lbs and 6 lbs when pushed down onto the scale.
I think I found some lighter springs for the old LST2 shocks I already have, which should get them to where I want it.
my new springs showed up for the LST2 shocks. I found a set of white Losi springs and a set of black Raven springs.
The black Raven springs are the tallest and firmest, followed by the white Losi springs and lastly, the unknown chrome springs. I think the white springs are a little lighter spring rate, but really not by much.
I'm going to run the white ones as a starting point and adjust from there if needed.
Hoping I get a chance to do some welding the next couple days, as I got the left frame rail cut, bent and the corner section set in place. Time to practice spot wedding...
