If you want it to, sure. That's my pointdose the name change when the combo changes like one wheel and tire combo called kevin maybe change the tires dose the name change to sherly
If everybody in your circle knows you refers to your wheel+tire combos as Kevin or Sherly, then when the conversation about the supportive rolling disc that makes it easier for you to move things comes up, people will understand what your referring to when you grab your "Sherlys"
When I say "tire" , I'm specifically referring to the (often) rubber disc wrapped around a wheel. The wheel and tire combo is then (often) mounted to the thing to be moved.
Sent from my Pixel 7 using Tapatalk
