Zero's Class 3...
Wow... so grenaded the inside pinion bearing on the rear axle, which of course effed up the axle so gotta replace it.
Definitely going to replace it with a bushing. Bushing may wear, but it won't explode. :)
So first action shots. Other than the bearing, works well and man it has an uber tight turning radius with the 4WS activated! Am going to lower the ride height a bit more though.
Hi thzero,
Nice build...such a passion to fabricate the cage.
What are you running on 2 speed servo? base on your diagram what if it been using for vanquish hurtz dig function. Any overload for the esc? Thanks.
I'm plan to build like your setup but with plus a dig. Is it a must to put 3 bec on this rig? Can only single bec like castle diagram enough to run 3 servos? sorry I'm new in this.
You could run the bigger castle bec. Johnnyh66 is doing that on his rig. I went with my approach as I had a bunch of smaller becs and for packaging reasons.
Two castle becs are used, plus the bec in the castle mamba max pro but the latter is only for the lights and receiver.
