Go Back   RCCrawler Forums > Miscellaneous > 1:1 Full Size Vehicles
Thread: Post Your Cherokee xj Here
Old 10-22-2014, 11:08 AM   #21
Default Re: Post Your Cherokee xj Here
My old XJ
92 4.0 4x4
6.5" Rubicon Express short arm lift on 33's
ARB Bull bar up front
Custom 4x4 rear bumper with swingout tire carrier
FarmerMatt steel taillight housings with LED's
Richterat83 is offline   Reply With Quote
Old 10-22-2014, 12:55 PM   #22
Originally Posted by 87Matchief View Post
did u cut and fold the rear quarter panel or just cut it? looks good and ive been wanting to do this.. any advice?
Sorry took so long. Yes cut than folded them under.
Tweeternpi is offline   Reply With Quote
Old 10-23-2014, 08:02 PM   #23
Cut And Fold Rear Lower Quarter Panels - The Right Way! - JeepForum.com
Here is a link to a cut and fold its pretty easy and straight forward. let me kno if i can be of some help
87Matchief is offline   Reply With Quote
Old 10-23-2014, 08:04 PM   #24
seems like a lot but really not.
Old 10-23-2014, 10:27 PM   #25
Here is my 88 on Big Sluice on the Rubicon. Somewhere around 7.5" lift (lowering it soon) short arm with drop brackets
ae racer is offline   Reply With Quote
Old 10-24-2014, 01:24 AM   #26
$800 92 4.0 5spd. With 250k miles
HpD30, 760x joints, locker, 4.56s. Rear ford8.8 locked, and all that.
Custom 3inch lift with 12" travel shocks. iRO track bar, rusty arms, custom steering, hydro assist. Rear, prototype shackle relocation, gm lowering shackles, RE 3.5" springs with some leafs removed.
Fuel tank inside, doors removed, lots of trimming.
the_ocho is offline   Reply With Quote
Old 10-24-2014, 05:26 AM   #27
my XJ
UPSrat is offline   Reply With Quote
Old 11-23-2014, 03:00 PM   #28
Escalator xj: http://youtu.be/av8abEbdbCY
mikro383 is online now   Reply With Quote
Old 01-28-2015, 05:53 PM   #29
Hi all. I'm new to the forum. Just getting in to crawling. Been playing with an xj for a while. 97 4 door 6" IRO long arm, 5100 shocks, shackle boxes, 4:88 gears in some trussed axles with lockers, 33" mtrs. It works well.
Jerm97xj is offline   Reply With Quote
Old 01-28-2015, 07:00 PM   #30
I would post some pics of said jeep but either I'm too stupid or tapatalk is a pos. Or maybe android sucks... Dunno. Any advice would be appreciated. It let's me pick a picture from the gallery in my phone but then there is a pop up asking if I want use a saved post or discard it.
Old 01-29-2015, 10:40 AM   #31
Hey I know this is a few months old but be careful with the leafs removed I ran the same set up RE leafs with only the 3 long ones left and snapped both sides on a weak bounce took out the drive shaft too. Just a heads up, was fun driving the jeep out with the rear only ratchet strapped in and front wheels pulling haha.
mindless is offline   Reply With Quote
Old 02-19-2015, 02:50 PM   #32
first time my wife went with me. she had a blast.
itsjust me is offline   Reply With Quote
Old 02-24-2015, 12:32 PM   #33
jtp
when I first built it...
jtp is offline   Reply With Quote
Old 02-24-2015, 01:53 PM   #34
96 country 4.0 3"lift 31's (for now)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
bigsal39 is offline   Reply With Quote
Old 02-25-2015, 08:36 PM   #35
My 97 xj. Eventually ill turn it into a wheelin rig but that wont be for a while.
Sent from the clouds
Captainkickass is offline   Reply With Quote
Old 02-25-2015, 09:43 PM   #36
The wife's XJ and my XJ
95' 4.0, Rubicon express lift, 32's.. Light trail (for now)
And Mine is on the Hood! ...
winnerone23 is offline   Reply With Quote
Old 02-26-2015, 11:06 AM   #37
jtp
on the rubicon..
Old 02-27-2015, 07:17 PM   #38
96 DD
My 91 MJ Eliminator
My 92. Was a trail beater but it's become more of a parts vehicle here lately. Not sure what I'm doing with it.
Motorcharge is offline   Reply With Quote
Old 02-27-2015, 07:24 PM   #39
I've seen more and more XJ's with removable door's..
What needs done to achieve this?
Hard to do?
Old 02-28-2015, 04:15 AM   #40
Hard to do?
Nope. On the older style you just need a dremel and reinforced cut off wheels. Cut the bottom part of the hinge off for the drivers side, remove the limiting straps. Odds are it's going to be hard to pull off due to age, so you can stick a bottle jack on a wheel and use it on the bottom of the door. Couple pumps to get it moving and it comes right off. Drill the hinge on the body out slightly to allow the pins to go in and out easier and you're done. Passenger side you have to cut the top off, push the pins out and flip them over and put them back in from the top, otherwise it's exactly the same.
97+ is a bit different, but not difficult. Can't remember exactly how to do it off hand but if you google it there's lots of write ups with pictures.
Post Your Cherokee xj Here - Similar Threads
Jeep Cherokee never to late to post. DezertFox Axial SCX-10 7 04-29-2013 05:01 PM
Post your cherokee!!!!! rcjeeplover11 1.9 Scale Rigs 11 03-12-2011 08:06 AM
