Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: hotwheels000 72 blazer
Old 11-24-2009, 02:22 PM   #1
Default hotwheels000 72 blazer
I used a 72 blazer body that has been disco'd for 25 years or so,it was built in the 80's to mimick my 1:1.I have had it on display ever since.Finally a R/C that I utilize it on
I eliminated most of the un-needed plastic stuff like the spur gear cover,battery tray, and esc case.relocated the battery and esc.Added weight to the wheels etc.....
The body was bobbed in the rear, I was able to retain the inner fender wells but had to ditch the interior until I can buikld a proper scale frame with cantilever shocks and a transfer case.The hood opens to access the battery. I can run the stock Nimh or my 400 mh lipos in that location.
hotwheels000 is offline   Reply With Quote
Old 11-24-2009, 02:28 PM   #2
Can we get some more pics with the body off to see those mods going on.
wheelhead4x4 is offline   Reply With Quote
Old 11-24-2009, 02:35 PM   #3
Sorry,unfortunatly the wife borrowed my camera and she is in Levenworth for T day. When I get there I will take some more and try to download them from there.
Old 11-24-2009, 02:37 PM   #4
I love the Blazer Devlin !
Cave Dave is offline   Reply With Quote
Old 11-24-2009, 02:40 PM   #5
Gay to the 9th power......
psst..what time does RCH close anyway? he he
HotRodJosh is offline   Reply With Quote
Old 11-24-2009, 02:47 PM   #6
Thanks Dave
Josh, i was gong to call you when I got there...they have to RTR and will have 6 bnd's buy Friday
Old 11-24-2009, 04:03 PM   #7
That looks perfect on there, Is that a plastic body or die-cast? I think i have a die-cast one of those somewere
1badxj is offline   Reply With Quote
Old 11-24-2009, 05:32 PM   #8
Monogram 1/24th plastic model
Old 11-24-2009, 05:36 PM   #9
Just got back from the hardware store.3/8 glav lock washers fit nicely inside the wheel around the hexall you need to do is bend them flat.
A stop at the hobby shop and I now have all the materials for a ladder type frame. I will be using brass rectangle hollow stock for the rails and flat stock for the x-members....
Shes ging to kill me building this at the condo on vacation well, that and she was buying me one for x-mas also, oh well, guess I will have 2 of them
Old 11-24-2009, 06:19 PM   #10
you gonna have this at the next comp or gtg i wanna see it in person i want 1 bad
crawler pilot is offline   Reply With Quote
Old 11-24-2009, 06:22 PM   #11
www.team3sixrc.com
I knew you were gonna do that. My god your nutz. looks great Dev.
team3six is offline   Reply With Quote
Old 11-24-2009, 07:34 PM   #12
Blazer body looks great! cant wait to see some scale chassis for theses
finishline is offline   Reply With Quote
Old 11-24-2009, 07:59 PM   #13
Ran it for 20 minutes on a 300mh 20c lipoShut it down and put it on the charger,I am curious as to how many milliamps it will take to charge to full. I dont trust the lipo campatable stock esc,not sure if it has cut off and untill I order more of these little lipos i dont want to toast one.
Much better wheel speed and oesnt dump/drain like the stocker after a few minutes.
Old 11-24-2009, 08:10 PM   #14
Looks good. How much rub are you getting?
King of Beers is offline   Reply With Quote
Old 11-24-2009, 09:00 PM   #15
At full stuff she rubs a bit, I enlarged the wheel wells a bit but didnt want to go to far and ruin the look.
Just checked the charger, took 230mh...Next time I will run 25 min to see what happens
Old 11-24-2009, 09:12 PM   #16
Dev...I was "thinkin" about these lil' things a bit...could ya limit up travel just a hair to keep it outta the wheelwells?
psst....I found leaf spring material...he he
Old 11-24-2009, 10:21 PM   #17
yep, already done since the last post...run a battery,charge battery, work on mods while battery charges, run truck....repeat as necesary
Cant wait to see your build, what did you come up with ?
Old 11-24-2009, 11:07 PM   #18
This the one you were telling me about. Looks very cool!
IssyCrwlr is offline   Reply With Quote
Old 11-25-2009, 12:43 AM   #19
Actually it's an old AMT 1/25 scale kit and Model King teamed with RC2/ERTL a few years back and had a really nice limited run re-issue of it. IIRC there was also a monster truck version that was released in teh 80's too!
BJoe is offline   Reply With Quote
Old 11-25-2009, 08:19 AM   #20
yes, thanks. It is a fun little time kiler.
Thanks, it was a long time ago and i guessed at the manufacture
