01-25-2010, 11:03 AM | #1 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| Project: "Payote" (WARCRC.org Team Trail Truck)
WARCRC started a new scale class called "Team Trail Run". Here are the specs for the class... http://warcrc.org/phpBB/viewtopic.php?f=43&t=7274 Here are my truck specs... Body: Tamiya Pajero http://www.rpphobby.com/product_p/tam9335500.htm Trans: Axial http://www3.towerhobbies.com/cgi-bin...&I=LXTBD6&P=ML Transfer case: RC4WD Killer Transfer case http://www.rpphobby.com/ProductDetai...de=RC4X%2D0434 Drive Lines: Axial Axles: Shortened Tamiya TLTs http://www.rpphobby.com/product_p/tam84028.htm Suspenion Setup: 4 Link Servo: Hitec HS-5625MG http://www3.towerhobbies.com/cgi-bin...&I=LXUZ76&P=ML Winch: 3Racing Automatic Crawler Winch (1/10 Size) http://www.rpphobby.com/product_p/3racr01-27.htm Chassis: 1/2" Steel Square tube ESC: Novak http://www3.towerhobbies.com/cgi-bin...&I=LXSFR0&P=ML Motor: 35t http://www3.towerhobbies.com/cgi-bin...?&I=LXTRC0&P=7 Rims: RC4WD OEM Steel 1.9 Stock Beadlock Wheel - Black Edition http://www.rpphobby.com/product_p/rc4bl66.htm Tires: Prowler XS Scale 1.9 Tires http://www.rpphobby.com/product_p/rc4prowler19.htm Shocks: Scale 80mm White Shocks with Internal Springs http://www.rc4wdstore.com/2/product_...roducts_id=437 Last edited by justinart24; 04-02-2010 at 03:09 PM. |
01-25-2010, 11:07 AM | #2 |
Updates... -Bent/Cut/Painted Chassis -Made front links -Made servo plate and mounted servo -Mounted RC4WD shocks(Will be swapping them out with stock SCX10 shocks) -Made Skid plate |
01-25-2010, 11:07 AM | #3 |
Updates... -Mounted R2 trans -Mounted Transfercase/drivelines |
01-25-2010, 12:32 PM | #4 |
Pebble Pounder Join Date: Dec 2008 Location: California
nice work on the chassis! are you getting good travel with the front suspension before you have motor/servo clearance issues? i've been thinking of doing something like this except with a frame mounted servo.
01-25-2010, 12:43 PM | #5 | |
-No issues per the motor and servo hitting. I made sure there was room. -Travel is ok, not the greatest. -I was going to do the frame mounted servo but since I narrowed the TLT's I was thinkig there would have been a lot of bump steer due to the steering link being so short. :P Last edited by justinart24; 01-25-2010 at 12:49 PM. | |
01-25-2010, 12:49 PM | #6 |
Quarry Creeper Join Date: Sep 2008 Location: everett
How many projects you doin right now? Did you scrap that 8x8 you were working on?
01-25-2010, 12:57 PM | #7 | |
-1.9 Hilux *Done -2.2 Clod scaler 80% done -1.9 Pajero 30% Done -8x8 10% Done(Just bought parts for it last week, leafs, double output shafts parts and etc.) -TC5R road car 50% Done -TC5F drift car 50% Done -Losi MRC To many builds, not enough time(I got 6 weeks of vaca piled up though.) | |
01-25-2010, 01:16 PM | #8 |
Quarry Creeper Join Date: Jul 2007 Location: Dallas, TX
Why are you using a RC4WD R2 transmission and a RC4WD Killer transfer? Couldn't you just move the R2 down at the Killer transfer's location and just use the R2 for 4 wheel drive?
01-25-2010, 01:26 PM | #9 |
| I think you might be a bit confused on how a transfer case works, you still get 4WD(I currently don’t have the rear driveline hooked up because the rear axle isn’t mounted yet) but then you get to have the motor somewhere else. I am running the R2/transfer case to get more weight up front(a bit more scale too J ) and to make more room for the future interior. |
01-27-2010, 09:56 AM | #10 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
This thing going to be done in time to run at Brandons? Better get a move on.... |
01-27-2010, 10:28 AM | #11 |
01-27-2010, 10:39 AM | #12 |
01-27-2010, 10:54 AM | #13 |
Yeah, should be a blast! |
01-27-2010, 09:39 PM | #14 |
Updates... -Got rear axle mounted -Servo mounted and links made (Will Make sleeves for theh threaded rod later) -Got almost all the wiring done Well the flex is too bad, hope the weight I put in the tires later will help out with that. To do list...too much to list. |
01-27-2010, 10:35 PM | #15 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
| Peyote |
01-27-2010, 11:27 PM | #16 |
Rock Crawler Join Date: Jul 2009 Location: Colorado Springs
I like the builds! there alot more scale!
01-29-2010, 05:37 PM | #17 |
01-29-2010, 05:38 PM | #18 |
Picked up my paint today. It will be "Inca Gold" with black fenders. Sample pic, just from the web. http://www.testors.com/products/137189 |
01-29-2010, 06:19 PM | #19 |
RCC Addict Join Date: Dec 2007 Location: Calgary
great color I'm using the same color for a project I have on the go.
01-30-2010, 02:10 AM | #20 |
Got it all painted tonight. |
