Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: stock high lift questions
Old 12-20-2010, 08:19 PM   #1
Default stock high lift questions
first one in stock position what is a good futaba servo? what specs should i look for?
is there a direct replacement for the 3 speed?
when working on the body is primer then steel wool the best way to get it smooth?
thanks for any help, i'll add more when i think of them
TZona is offline   Reply With Quote
Old 01-03-2011, 08:44 AM   #2
On the servo just at least get a metal gear for longivity with at least 100 lb of torque. This would work S3305 High-Torque Std Servo MG. Use 2 to 3000 grit water type sandpapper. Get it at a autobody shop or a place that sells car paint on the body! Dont use steel wool
Todders
mud-sweat-gears is offline   Reply With Quote
Old 01-08-2011, 06:46 AM   #3
I thought RC4WD had a clocked tranny that fit the F350...I made a custom mount and dropped in an Axial one....
the_ghetto_rig is offline   Reply With Quote
