Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: 1.55 SxS Race Rzr
Old 02-23-2017, 07:09 PM   #1
Default 1.55 SxS Race Rzr
Spring better come soon or im going to run out of things to build. Hope im posting in the right place, But here we go.
Wanted to build something in 1.55 for awhile now, even tire and wheel choices are very limited. Bought a 1/16 revo roller to plant rc4wd stamped bead locks and mud thrasher tires on.
Got it all built up and hated it, as you can see in the picture it looks like a golf cart. Luckily found a really awesome guy on another forum that made a pdf template for a stretched chassis plate.
Bought a scroll saw and made one up...
Sent from my SM-G925V using Tapatalk
WillWorkForAlumParts is offline   Reply With Quote
Old 02-23-2017, 07:10 PM   #2
Default Re: 1.55 SxS Race Rzr
Old 02-23-2017, 07:13 PM   #3
Old 02-23-2017, 07:14 PM   #4
Old 02-23-2017, 07:15 PM   #5
I will eventually relocate the source and give due credit to the designer of this.
Old 02-23-2017, 07:17 PM   #6
1st time using scroll saw and pretty much what you expect.
Old 02-28-2017, 09:02 AM   #7
Following closely like to see how this ends up
jdereu is offline   Reply With Quote
Old 02-28-2017, 10:15 AM   #8
Moderator
JatoTheRipper's Avatar
That's cool. Nice work.
Old 02-28-2017, 05:58 PM   #9
Interesting idea. Be awesome seeing a couple of these shredding through the woods
xigtc is offline   Reply With Quote
Old 02-28-2017, 06:47 PM   #10
Really like the added length and look of chassis plate.
Old 02-28-2017, 06:50 PM   #11
I decided to make a departure from build plan here and spend more money. Never happens. I want swing arm suspension like new can am x3. Will eventually run 90mm and 100mm gmade rsd shocks.
Old 03-01-2017, 08:40 PM   #12
Electronics mounted. Functional but rear diff is stripped. Bought it used on ebay, feelin the burn.
Old 03-04-2017, 02:23 PM   #13
Did you use pop rivets to keep the cage together...?
MiteyF is offline   Reply With Quote
Old 03-04-2017, 05:16 PM   #14
I did. Although its a less spectacular way to build a cage, i find it gives more structure to some joints. Especially after you solder them.
Old 03-10-2017, 12:52 PM   #15
Ditched the old cage and used alum sheet metal for body. Much easier to acheive the look im going for, while also losing some weight.
Old 03-10-2017, 12:52 PM   #16
Got alot more finish work ahead.
Old 03-10-2017, 12:53 PM   #17
Damn this is it, we'll see if i can make it happen...
Old 03-10-2017, 09:14 PM   #18
Little gold and red in black should do the trick.
Old 03-28-2017, 12:06 PM   #19
almost looks right
Old 03-28-2017, 12:07 PM   #20
1.55 SxS Race Rzr - Similar Threads
1.55" Proline TSL SXs JeremyH Tires and Wheels 20 05-13-2018 03:39 PM
UTV/SxS - Looking at getting one. 2JSC Chit Chat 14 09-21-2016 06:38 AM
SXS rides. Reflection 1:1 Full Size Vehicles 10 04-07-2016 05:12 PM
CRAZY Polaris RZR race/demolition derby! heinie_21 Chit Chat 18 02-24-2013 10:28 AM
Waterproofing SxS packs? redrum_racer Electronics 4 12-31-2006 11:16 PM
