Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: hi lux transmission options
Old 11-24-2008, 05:51 PM   #1
Default hi lux transmission options
Im looking forward to get a hi lux and i want to make it scaled but the transmission is in the way of the interior. I want to keep my 3 speed so what are some options on the transmissions so i could put an interior in the car.
4x4wheelier is offline   Reply With Quote
Old 11-24-2008, 06:28 PM   #2
i think i would lose the three speed, and get one of rc4wds two speeds
tanner is offline   Reply With Quote
Old 11-24-2008, 06:57 PM   #3
divorced tcase-mod it so the 3speed is under the hood and connect it to a tcase under the cab
0778drz110 is offline   Reply With Quote
Old 11-24-2008, 07:48 PM   #4
Please explain the divorced method because I am in a similar situation.
F-150Highlift is offline   Reply With Quote
Old 11-24-2008, 08:29 PM   #5
Dont know if anybody else tried this, but on the front face of the gearbow there is 2 holes about 3/4in apart under the spur gear. if you drill these out you can fit a motor on the front side of the tranny and get it a few inches lower. Only works with the stock gearing though...
I spaced my motor away from the plate with spare axle links drilled through all the way and cut to the correct length.
The1nonlyJ is offline   Reply With Quote
Old 11-25-2008, 05:17 PM   #6
do you have a pic of this, this could help me out alot.
Old 11-25-2008, 06:01 PM   #7
You mount the transmission under the hood of the truck, then run a driveshaft from it to a second transmission or transfer case in the center of the truck which then turns your driveshafts.
Trike Kid is offline   Reply With Quote
Old 11-25-2008, 07:08 PM   #8
people who got ideas should put them on here. then people have an idea
