06-01-2008, 03:25 PM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
| New Project! Tom's Toy (updated photo's on 7/5)
Well I am back in and trying to get a few older projects done and starting a new one. Got this new Hilux from the LHS friday. Got a few other parts for it and more on the way. List of the goodies. Hilux Body set K2-5 Chassis Tamiya TC shocks RC4WD 2 Speed Holmes Hobbies 10 turn Puller Mamba Max ESC Castle BEC JR 8711 Servo TLT Axles CVD's in the front RC4WD stright axles in the rear MSD C hubs front MSD lockouts in rear Bruiser Interior Clear Glass for cab MSD 1.9 Beadlocks RC4WD Rock Crushers 1.9 On to some photos to get things started. More to come! Last edited by Racer4Life; 07-05-2008 at 09:20 PM. |
06-01-2008, 03:39 PM | #2 |
Rock Crawler Join Date: Oct 2007 Location: Miami
Very nice. Now get started! |
06-01-2008, 08:18 PM | #3 |
06-01-2008, 09:41 PM | #4 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
my adress!
06-02-2008, 04:47 AM | #5 |
I wanna be Dave Join Date: Nov 2005 Location: Here
Can't wait to see what you do...
06-02-2008, 11:13 AM | #6 |
I wanna be Dave Join Date: Jun 2004 Location: Whales
This should be good |
06-02-2008, 07:16 PM | #7 |
06-02-2008, 08:38 PM | #8 |
RCC Addict Join Date: Apr 2004 Location: 5280
06-02-2008, 09:12 PM | #9 |
Did a little work tonight. Got the Front axle blacked out a little. Probably going to hack the servo mounts off. Figure since its going to be scale I will need to mount the servo up and out of the way. Here is the bed. Shortened it a small bit. |
06-03-2008, 07:29 PM | #10 |
Threw the chassis together to get a look at the body on it. R2 2 speed should fit really good even with the old school interior. Interior is really nice. Can't remember who I got it from, but it is detailed nicely. Filled the body mount holes. Was really disappointed about the rear glass, so I took it apon myself to fix it. |
06-04-2008, 06:07 AM | #11 |
Rock Crawler Join Date: Aug 2005 Location: salunga
looking good so far tom |
06-05-2008, 04:27 PM | #12 |
Thanks Sods... Here is the back window finished and primed. Came out really nice. I hand cut the styrene to fit. Then I used some styrene glue to hold it in place. I then went back over the inside with some styrene goop I made. (styrene glue and small peices of styrene) makes a great holding formula. Used some spot body filler and then sanded. The rear Hilux window fits perfectly in the cut out. Not sure if I will use it, as I ordered the clear Kamtec glass for this one. Here are some build items that showed up. Thanks to RC4WD, and JP Customs. Got the shocks from my LHS. |
06-05-2008, 05:38 PM | #13 |
Hey Tom, this is going to one fine ride. Nice work so far bud. |
06-06-2008, 09:26 PM | #14 | |
Thanks!! how you been doing??? Got a liitle work done last night and tonight. It is a roller! The powerplant. Since I am using this motor I chose not to use the two speed. This thing pull wheelies as it sits. Since the extra channel was open on the reciever (not using the two speed), I installed a winch. Everythng is stuffed in there really well. Today I received the clear glass from Kamtec. Got the rest of the bed body work completed. I think it might be ready for some paint. Added a fairlead to the front bumper so the winch line can come thru. And here it is setting all mocked up. now its time to tear it all down and make the delrin links and fix any short cuts. | |
06-06-2008, 09:31 PM | #15 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Next up on Doc Jeeps to buy list - a high lux. I am not a Yota fan by any means in the 1:1 world. BUt in a scale format these things are seriously growing on me. Great build!
06-07-2008, 06:42 AM | #16 |
Quarry Creeper Join Date: Apr 2008 Location: columbus
Since the extra channel was open on the reciever (not using the two speed), I installed a winch. How did you get the bobin to stay on the servo? |
06-07-2008, 06:46 AM | #17 |
06-07-2008, 09:23 AM | #18 |
Looks killer Tom!! Now when is that badboy showing up on the doorstep for some testing |
06-07-2008, 02:32 PM | #19 | |
Actually...I have a CR-01 that needs built. Are you interested?? | |
06-07-2008, 03:18 PM | #20 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
I like how you keep the line going straight into/out of the the spool. Thats one of the problems I was running into on my build. I ended up ghetto fabbing a line stay using an antenna tube zip tied to a piece of steel. Looks horrible but it gets the job done, your's looks much better!
