| | #1 |
| Rock Crawler Join Date: May 2008 Location: Sumter, SC
| I am currently procuring all the guts needed for my scale build. I have a pretty clear idea of what I want and I decided to share these ideas with all of you! I have a Chevrolet Silverado EXT cab on the way. It is the Intimidator SS toy truck so many have seen on this very forum. I don't have a chassis yet but I am working on selling some stuff to get one and other stuff. The rear will be an Axial axle with Tamyia leafs and RC18T shocks. The front was going to be the same but I figured a real Silverado has independent front sus. I turned to my nitro RS4 on-road car and though I could make it's front sus. work on my truck. So far it looks like I can make it work but until I get the chassis I won't know for sure. Here are some pics. Stock RS4 front suspension: ![]() I modified one side to get more down travel: ![]() As you can see I get a good bit more down travel and this will allow the diff to be tucked under the chassis. I am so excited about this build I wish I had more info for you but this is it for now. Stay tuned! Last edited by chops1sc; 07-15-2008 at 10:11 AM. |
| Sponsored Links | |
| | #2 |
| Well, I got both sides trimmed so they have way more travel than before. Now I have to find a way to change the input shaft from a dogbone socket to one that will accept a yoke. I think I will try the pinion from an Axial diff, they are surprisingly alike. One thing that was unexpected and maybe a little lucky was the gear ratio in the RS4 diff is exactly the same as the Axial axle ![]() Last edited by chops1sc; 07-15-2008 at 10:12 AM. |
| | #3 |
| Quarry Creeper Join Date: Apr 2008 Location: columbus
| looks good. |
| | #4 |
| Newbie Join Date: Jun 2008 Location: va
| are you going to leave it belt drive or how are you going to change that? |
| | #5 |
| My RS4 is a shaft-driven nitro. No belts. I think I am going to get the Axial pinion and shaft to use in place of the dogbone system. If the two pinions are different I will have to come up with something but I am fairly certain they are the same. My next concern with this setup is steering. The RS4 uses a dual bell-crank system. I will have to make something that will act independently of each side. Might be the hardest thing to work out. |
| | #6 |
| Newbie Join Date: Jan 2008 Location: Monterey Park
| really like the idea.... fresh n' new... keep' em coming |
| | #7 |
| Well, I have all the major components on order and on the way. Here is what my build will consist of: Chevy Silverado SS (yes another one, lol) Trail Beater chassis (bought from run2jeepn) Axial Transmission (tranny and motor from danielk) Special motor (don't know much about it yet Axial rear axle from the RTR RS4 front end diff/control arms (IFS) Tamyia leafs for rear axle 60mm scale shocks front and rear (also from run2jeepn) 1.9 Mud Slingers with alloy wheels (from xjwalt666) Tamyia Pajero wheels (also HPI stockers) Stampede shafts with Axial yokes Traxxas XL-5 (waterproof version) MG 946R servo (from run2jeepn) Spektrum SR3100 That about does it so far! I know I'm gonna need a lot more when I start the build. I will get pics of the parts spread as soon as I get everything in! Last edited by chops1sc; 07-17-2008 at 03:35 PM. |
| | #8 |
| RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| I totally respect the IFS front, but as in a real 1:1 that is very limiting to articulation. Aside from the parts available is this the route that you want to go? Obviously that is the case. I would almost invest in another AX axle and do straight. But, it is your build and I would never knock what you are doing as I think it is pretty cool. Just seems like a waste to do all of that modifying and money to not have a good flex setup. |
| | #9 | |
| | #10 |
| ✘ ɹǝʞɔɐʇs ʞɔoɹ ✘ ![]() Join Date: Jun 2008 Location: Wasilla
| looking good man keep it up. - tre |
| | #11 | |
I say build it then damnit! | |
| | #12 |
| Got some gear in today! Here are some update pics.... Tranny, motor, shafts, rear axle, Mudslingers, mocked up at 12" WB. ![]() The IFS... ![]() The rear axle (from an RTR)... ![]() Can't wait for more parts!! Last edited by chops1sc; 07-15-2008 at 10:13 AM. |
| | #13 |
| Quarry Creeper Join Date: Jan 2006 Location: colchester
| hey chops sounds like its going to be a great build. Glad to see the wheels and tires finally being used for something. Definitely going to keep an eye on this one, should be good |
| | #14 |
| | #15 |
| Rock Crawler Join Date: Oct 2007 Location: Miami
| Looks very good. |
| | #16 |
| I joined the Band! Join Date: Jul 2005 Location: Westland
| wow nice job |
| | #17 |
| Yup, looks like a real 1:1 Chevy with a dropped cross member, lol. J/K - looking good there! |
| | #18 |
| I got the steering figured out. I just cut 2 links from my AX-10 parts bin and connected the steering knuckles to the servo horn. The servo is mounted to my vertical supports. It was easier than I thought it would be. ![]() Now I gotta get the electrics in place. I am using a Spektrum SR3100 and a Traxxas XL-5 from the Slash (waterproof FTW). |
| | #19 |
| Newbie Join Date: Jul 2008 Location: Phoenix
| Wow! This thing is sweet. I can't wait to see it done and how the suspension works. |
| | #20 | |
| Thread Tools | |
| Display Modes | |
