Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: K2-5 F-250 Scaler Build
Old 07-08-2008, 04:12 PM   #1
onlyinajeepxj's Avatar
Default NEW K2-5 F-250 Scaler Build
I found a complete High Lift body that had a bad paint job on it. It looked like it could be revived fairly easily, so I bought it. I felt it was worth a try.
I plan to build it up as a clone of my Father-In-Laws 1:1 F-250. This will be my first scale build, so bear with me...
I liked the look of Brett's new K2-5 chassis, so I picked one up. It fits this body like a glove! Nice job, Brett.
I'm not completely decided on the specs for the build, but I know I will be using parts I have, as well as, a few new ones.
Here's what I'm thinking:
Chassis - K2-5
Axles - TLT
Motor - Holmes Revolver Black
Controller - Quark 33 Pro Car
Servo - TowerPro
Trans - Axial
Wheels - High Lift
Tires - Rock Crushers
I'll be posting pics along the way. I'm open to comments and suggestions.
I should note that this won't be a complete scale build. I'm planning on making it 4-link front and rear. Also, I'm not sure if I'm going to use the K2-5 shock mounts or the High Lift shock towers. Details to be decided later, I guess...
onlyinajeepxj is offline   Reply With Quote
Old 07-08-2008, 04:19 PM   #2
Here is a picture of the K2-5 chassis after a few coats of flat black paint. It's a nice looking chassis if I do say so myself.
Here is a picture of the body when I brought it home. The paint wasn't to bad, but I wasn't sure what kind of paint it was. I thought I would play it safe and strip it down with oven cleaner.
Old 07-08-2008, 07:02 PM   #3
looks good so far.
Georgerm is offline   Reply With Quote
Old 07-08-2008, 08:07 PM   #4
The oven cleaner worked very well. It took four treatments over the course of two days to completely remove the paint. I used generic Family Dollar oven cleaner at a buck a can.
My inspiration truck is white with metallic charcoal along the bottom. It also has logos on the doors, but those will come later.
First, I primed the body. I followed that with a little bit of wet sanding in preparation for the final coats. I used Dupli-Color Acrylic Enamal straight from the ol' rattle can. I think the finish turned out pretty good.
I did a little bit of detail painting with some thinned out flat black paint. I'm relatively happy with the results.
I couldn't find paint for the light lenses locally, so I used a red and orange Sharpie marker.
The holes in the body will be covered up by "scale details" a little bit later on in the build.
Here are some pics of the progress.
Old 07-08-2008, 09:57 PM   #5
Looks good man!!! What is the length of your skid (not width)???
countryboy4life is offline   Reply With Quote
Old 07-08-2008, 10:51 PM   #6
2 3/16"
It was designed for an Axial transmission.
Old 07-08-2008, 10:51 PM   #7
701 Technique's Avatar
body work looks great whats your plan for mounting the body to the K2-5?
701 Technique is offline   Reply With Quote
Old 07-09-2008, 06:29 AM   #8
Not quite sure yet. I'll probably use the stock High Lift front mount. It seems to line up just right. For the rear I'll probably use velcro.
Old 07-09-2008, 09:31 PM   #9
I managed to get a little bit done tonight.
I mounted the Axial trans with an outrunner plate for the Holmes Revolver Black. Everything went smoothly.
I decided to use the K2-5 shock mounts instead of the High Lift shock towers. I want this thing to perform pretty well when it's all said and done. The suspension geometry is a little bit more aggressive with the K2-5 mounts. Ultimately, it will just work better.
I am going with a set of Tamiya touring car shocks that I already had. They fit perfectly. I have some yellow springs that I'll probably be using. I believe they are a little bit softer if I remember right.
Next, I cut some trays for the battery/radio/esc to be mounted on. I used some 1/8" PVC that I had laying around. I think it should work pretty well.
I also painted up the link mounts. I don't really care for the look of the silver with the black axles. They got a few coats of etching primer followed by some flat black paint.
Hopefully I'll get to the axles/4-link tomorrow.
Old 07-10-2008, 08:36 PM   #10
I got the TLT axles built up tonight. I beefed them up with the following:
Full bearings
RCP straight axle kit
RCP lockers
RCP super-max clearance knuckles
MIP CVDs
I still want to get some axle C's, but I'll probably wait until I break the stock units.
Now I'm just waiting on some parts to make it a roller. They should be here tomorrow.
Old 07-10-2008, 11:56 PM   #11
Progress is lookin good Im about to start the same type of build except with a hilux body, I already have the black K2-5, the body, TLT axles and shocks in the mail.
I was going to use the TLT shocks with the highlift shock mounts but I think you got a good thing going with the Tamiya touring car shocks, whats the length of those eye to eye and do you know a part number for like tower hobbies?
one more thing, where do you get your PVC? I think that looks great on there
Old 07-11-2008, 07:53 AM   #12
I wanted to use a Hilux body for my build, as well. I found this one for $20.00, so I couldn't pass it up.
I'll get back to you on the shock length. I'm at work at the moment. I'm not sure what the part number is. I've had them for a while.
I'm not completely sure they'll work yet. I'll know after I do the 4-link and axle install tonight.
We use sheet PVC at work for certain things. I picked up a scrap and took it home with me.
