| | #1 |
| RCC Addict Join Date: Oct 2008 Location: Lakehood, Crawlerado
| Welcome to the build thread for my new scale project. Ok, a little back story first, then pics. I bought a Losi Mini LST right before they went away on clearance and got the lipo rebate as well, all for just over $100. It was fun, but the dual servos are not the best set-up for this truck. The tie rod between the servo rod is really to blame, it wouldn't keep the servos aligned like it should have, and was annoying. Also, the suspension is nice and beefy, but the shocks stayed compressed at rest. I took them apart rebuilt, and they did the same. Last annoyance, the center diff would unload the front onto the rear way too much, all these made dirt handling tough. Rather than buy all the parts to fix the annoyances (servo tie rod, alum shocks with ti nitride shafts, ball diffs) and after seeing the start of a similar build here, I decided to make this a scaler. The Losi is a great truck, and with a little modification, can be bulletproof and a lot of fun. For the body, I bought a Radio Shack H2 body from the mattracks hummer, the wagon version rather than the newer SUT. I had fully intended on making a scale project out of it, but at the time didn't have any spare axles and needed to raise a little cash, so up on ebay it went, 3 times! I had 6-10 watchers in each auction, but no bites. There was even a guy that offered to pay me a week after the auction ended, but ended up backing out of the deal. The third time was the strikeout. I decided to keep it and eventually make something out of it. I tossed it in to the storage, and forgot about it until recently. While in there, I'm not sure what happened to it, but there are small spots where the top layer of "clear" is damaged (see pics below) so I'll need to paint it up. The Axial trans (not in pics below) and temporary tires came from my Trail monster build. I narrowed the tires to fit the MLST wheels. I plan to use the stock axial driveshafts with maxx yokes on the axle side to fit over the MLST dog bone cups. I also plan to lock the front and rear diffs, but may end up getting stronger diffs. These tires are a little tall for what I want, and I plan to get 1.9 flat irons on some inexpensive beadlocks. There's a lot of building to go, but this thread will serve to chronicle the process, and possibly inspire someone else. (Also to help me remember what changes I make) Well, enough words, let see some pics! ![]() Here's about the ride height I want, although the rear will be lifted a little more. ![]() Another ride height view, WB will be about 11.25" or 11.5" ![]() Rear ride height view ![]() Width looks just right ![]() Narrowed tires, to see how wide they were before, just look at the rims holding the body up in the above pics, I took out .75" total. ![]() Suspension lock outs made from Lexan ![]() I'm still messing with the steering to figure out what I want to do with it. I'll get that done probably after the new wheels to see what kind of clearance I'll have ![]() ![]() Hard to see from this angle, but these tires are about 4.5" with the rubber studs, the flat irons are supposed to be about 4.125" - 4.25" ![]() Width now is about 8.25 - 8.5 ![]() Tires are just under 2" wide ![]() Center clearance is awesome, 2.5" ![]() And here's what I was talking about with the damaged clear top coat. Still have a long way to go... |
| Sponsored Links | |
| | #2 |
| OK, here's some pics of the paint: Flat Black and Satin Silver sprayed down: ![]() ![]() ![]() Close-Up: ![]() With the clear coat, and the accessories put back on: ![]() ![]() ![]() ![]() ![]() Now, I need to figure out the decals, here's kind of what I was thinking, something farily simple: ![]() I have been looking at a few other police cars, and most of them have simple block fonts, and not a lot of them have the "to protect and serve" motto anymore. I'm going to have "Police" on the hood, and I'm still trying to figure out the tailgate decals. As far as the rest of the build goes, the next step is getting the frame figured out, and getting the tires. |
| | #3 |
| I posted this also on another forum, and a suggestion for the light bar was made: use clear red and blue lighters, drain the butane, cut 'em up, add lights, done. So, I will be looking for some very soon. I also found out the MLST diff is the same as in the MRC, so i will be getting the output shafts and plastic lockers very soon. Anyone know the diameter of the MRC output shaft? I think it's 4mm, but I just wanted to check. I'm also looking for a cheap place to get the graphics cut, so if anyone has suggestions, I'd be open to hear them. Thanks. |
| | #4 |
| Pebble Pounder Join Date: Mar 2009 Location: Whittier
| Sweet looks good |
| | #5 |
| | #6 |
| RCC Addict Join Date: Oct 2007 Location: Long Island-Land of one batch of rocks in Sag Harbor and at least one fellow crawler
| Very cool build! |
| | #7 |
| Thanks, I welcome all comments, so if you're looking at this thing thinking it's stupid, let me know. If you think it's awesome, let me know. If you have an idea or suggestion, well you know what to do. |
| | #8 |
| I am a Liar! Join Date: Aug 2007 Location: santa monica
| I have to admit I don't like Hummers but this is an interesting build. I like the 'theme' and the tip about clear colored bic lighters is genius! I'm most interested in your steering setup. I am in the middle of cutting up my cc-01 (also IFS) to accommodate a servo up front and use a tie rod to connect the two steering knuckles like you have. I wondered if it would work on an IFS setup or cause it to bind up somehow. Have you run a truck like that or was this set up like that stock? [edit: hit up elchupocabra, a member here. he did graphics for several of my rigs and does good work.] |
| | #9 | |||
![]() ![]() ![]() But, the wheelbase wasn't perfect, and I think it just looks goofy with the wheels sticking out that much. Quote:
![]() The stock set-up was two seperate mini servos, with their own steering link, it didn't keep the wheels aligned and they were weak servos. I ended up just making a servo plate/4-link mount out of 1/8" lexan to mount the standard servo. I may end up frame mounting it, since there's more competition points for that set-up. I'll look into it, thanks. | |||
| | #10 |
| Ok, I ordered some of these and these from losipartshouse.com, and installed them on the rear axle. The lockouts needed some modification to fit the MLST1 outdrives; a little drillwork, and it's done. The output shaft is 4mm, the axial driveshafts are 5mm, so I just shimmed it with some cardboard, and it spins centered. Still need to do this to the front axle. I also ordered these and these from myatomic.com since they offered free shipping for orders over $25. Still waiting on these (ordered thursday, so I expect them either tomorrow or tuesday.) I was going to go with the Losi MRC wheels and Flat Irons, but I realized the MRC wheels aren't true beadlocks, and the flat irons were taller than I wanted. Plus I spent $30 on the wheels and tires total. I'll probably order some 26mm 0 offset stock car wheels with Tamiya Hummer Tires for the spare and sell the other three. More to come... |
| Thread Tools | |
| Display Modes | |
