12-06-2009, 01:54 PM | #1 |
Newbie Join Date: Oct 2008 Location: summerville
| 6x6 SCX10
Ok im planning on building a scale 6x6 out of an SCX10 TR. I would like it to be similar to the one in this forum... http://www.rccrawler.com/forum/axial-scx-10/170883-broke-mofo-scx10-6x6-unimog-build.html#post1718260 What i need to know is what all i need for a complete conversion. This is what i know so far that i will need... 1) Extra Axial Rear Axle 2) Extra Pinion and Outdrive Case 3) Extra Linkages 4) Chassis Extension (have no clue how to do) 5) Extra Driveshaft 6) 2 Extra Shocks is there anything im forgetting please let me know.. and if anybody has any pics of a 6x6 scx10 that would be greatly appreciated also.. thanks |
12-06-2009, 02:04 PM | #2 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
I think you have it down so far. Just remeber you need 2 full axles, then you need another axle that has the pinion case, a spair pinion, and then another pinion case. Ive wanted to do a 6x6 for a while, igotit actually urged me to make one back when he made his. I will be watching what you go for |
12-06-2009, 02:44 PM | #3 |
Ok thank man, hey i gotta few more questions, what do i need to buy for the extra linkages and how many of em'? And for the chassis extension couldnt i just buy two more chassis rails and cut them in the right place then put the shock hoops on, instead of having to fab up a whole new thing? And one last one what driveshaft do i need to buy.
12-06-2009, 04:00 PM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: Syracuse
| Oh yea you forgot to post pics |
12-06-2009, 06:16 PM | #5 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
| Can't post pics on something that isn't even started yet :? Anyways, for the chassis extension, in the link you provided for the one that's the inspiration, it looks like he has a hacked up chassis screwed to the rear of the SCX10 chassis. |
12-06-2009, 08:08 PM | #6 |
I have a thread on here for my 6x6, but I used a Reign RC K2-6 chassis. I can share one bit of knowledge that I learned the hard way- when you are setting the wheelbase spacing between the rear axles, make sure you leave yourself enough room for a driveshaft that will have enough extension when the rear axles get twisted up. I had an issue w/ my rig that took a bit of head scratching to figure out, but it is working fine. Don't forget that you will need to flip the rear axle upside down so that the driveshaft will turn it in the correct direction. This brings up another slight issue- when you flip the rear axle, you no longer have a place to bolt on the upper link mount because the holes that you would normally use are now at the bottom of the axle. I was able to setup a counterbore bit w/ a #40 pilot and I turned the hex shaped holes into counterbored holes, then used some 3x10mm spacers to mount up the upper link. It looks like a factory part when it's complete. I'm also having to play w/ the spring rates on the rear axles, I'm going to end up using super soft springs so that the rear axles can float over the terrain. I modified SCX-10 shocks on my rig. Good luck with the build, these 6x6's are a lot of fun once you get them moving! |
12-27-2009, 06:02 PM | #7 | |
Rock Stacker Join Date: Jul 2009 Location: dusty foot path
06-03-2010, 07:31 AM | #8 |
Rock Stacker Join Date: Feb 2010 Location: Utah
"Reign RC is proud to release one of the first production 6x6 chassis's to the crawling market. The K2-6 chassis is designed to fit the needs of those of you wanting to build a 6x6. The design allows a builder to mount any of the Tamiya Tractor cabs or Bruder MAN/Actos cabs. The shark fin on the back makes it easy to 4 link all 3 axles, but if you prefer to leaf or make a walking beam setup you can easily cut off the fin and work from there. The chassis is based off the K2-5 chassis platform. The width is 3 1/8", the length is 21.5"." |
06-05-2010, 09:41 AM | #9 |
Quarry Creeper Join Date: Aug 2009 Location: Fresno
I think you would be better off selling your scx10 frame/body and just buying a 6x6 k2 chassis. 6x6 on a budget is very hard, you will need extra hardware, links, tires, and time. Your best bet is to either get some more posts up, or buy a star, so you can use the wanted/forsale section here. It will save you lots of $$. I have now built two 6x6 axial based rigs, and if you are going to run it hard, you need to go 4 link on the two rear axles. You will break/pop the 3 link axle mount all day with the stress of two rear axles. Good luck. Drunk |
