07-05-2010, 08:00 AM | #1 |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
| The Rust Bucket
I painted this body about 3 yrs ago & finally decided to build a good scaler out of it. I had it half-a$$ed put together as a scaler before but never did a build thread on it, so I figured its time to do it right. I started with a Proto chassis I picked up from someone off here ( its a diaz I think????) A slightly used R2 I had layin around along with a HH Tourquemaster 35t that also has very little use. First up was bolting the tranny to the chassis, I decided to bolt it directly to the chassis without using a skid.... (that will come later) Next up is the donor WK axles I had sittin around Quick mock up shot..... I re-used the links from the half a$$ed scaler for the lowers and the uppers..... The rear is done. I'm not happy with the shocks for now (full droop) but a lil more tweaking & some better scale shocks & maybe shock hoops might be in the near future. A couple shots of the front (the front shocks are laying down more than I like but that will soon change). The tires installed..... I think the WB is a lil too wide but I am debating on narrowing the axles to make the tires tuck or installing fender flares. And finally a quick shot of the body..... I still got a ton of work to do, but a decent roller for now. Hopefully I will be able to get it finished fairly quick but workin 84hrs a week I can only do so much at a time..... Any suggestions are always welcome Last edited by TONKA TOY; 07-05-2010 at 08:11 AM. Reason: re-size pics |
07-05-2010, 08:26 AM | #2 |
Rock Stacker Join Date: May 2010 Location: united states
you got a hell of a good start!!!!
07-12-2010, 04:20 PM | #3 |
Pebble Pounder Join Date: May 2010 Location: canada
looking good!!
