07-24-2010, 10:46 PM | #1 |
Rock Stacker Join Date: Feb 2010 Location: Utah
| Newbright JK truggy
I scored a beat up Newbright JK at my local Radio Shack and decided to start another project. I considered doing a 2.2 scaler project, but quickly decided I needed something more original. So the cutting began. After some styrene, green puddy and a coat of primer. Looking like a proper ratrod. Mock up with the Honcho cage. Testing flex with custom rear shocks and relocated mounts. |
07-24-2010, 11:01 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
That is F%$#ING awesome. NICE WORK!!!! Where are the rear shocks mounted up top. And what wheel base did you start with TR or Honcho? |
07-24-2010, 11:11 PM | #3 |
Thanks. I relocated the shocks inboard and down from the stock position. Once I found the perfect location for the shocks, I made a mount using delrin sheet and servo mounts. The new location changes the spring rate (WAY to stiff) so I rebuilt the shocks with a new hole in the plunger, super soft springs and 50wt oil. The result is a boat load more articulation from the rear. |
07-24-2010, 11:16 PM | #4 |
| The links are 1/4"aluminum rod threaded to 4M with RC4WD rod ends. The wheelbase is barely longer than a stock Honcho in the rear.
07-24-2010, 11:34 PM | #5 |
Very Nice. I may have to do that to my honcho. I'm diggin the body to. SICK MAN.
07-25-2010, 02:35 AM | #6 |
Rock Crawler Join Date: Feb 2009 Location: New England
Nice rig!! I would have not thought of doing that to this body but it works really well.
07-25-2010, 06:42 AM | #7 |
Rock Stacker Join Date: Oct 2008 Location: midland
nice body i could not do that to that body, but I do like it wish i had that skill to do that keep it going!!!!!!
07-25-2010, 12:59 PM | #8 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
Yeah, the honcho cage looks good on the back,keep it up.Its guna turn real nice.
07-25-2010, 03:54 PM | #9 |
I decided to replace the plastic TR bumper with a home made winch bumper with minimal overhang and uber-approach angles. First off I bent up some brass. Ugly brass all tacked up in place. Next up, the interior.... |
07-25-2010, 05:42 PM | #10 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Nice look JK Truggy |
07-25-2010, 08:01 PM | #11 |
Pebble Pounder Join Date: Jan 2009 Location: Central New York
Wow looks very good. I may have to do a project like this, with body cutting and using the same body! Really like how the honcho cage looks with it Ben |
07-25-2010, 09:13 PM | #12 |
Pebble Pounder Join Date: Apr 2010 Location: Massachusetts
I like that body.
07-25-2010, 10:58 PM | #13 |
Rock Crawler Join Date: Apr 2005 Location: Upland
Nice brass work. I like what you've done with that body. It looks really good. |
07-30-2010, 06:41 PM | #14 |
Thanks! Here's some shots at last week's comp. Maiden voyage for this rig. The suspension mods works perfectly. I couldn't have been happier. I painted the silver honcho bed sheet metal with satin black. Then dry brushed it over with silver paint to bring out the diamond plate and show some age. A good shot of the new rear articulation. ....oops. If you notice, I even took out the gate when I rolled... |
07-30-2010, 07:27 PM | #15 |
Rock Crawler Join Date: Jan 2009 Location: Jacksonville FL
im diggin it |
07-30-2010, 08:53 PM | #16 |
RCC Addict Join Date: Dec 2007 Location: Calgary
I'm really digging this build. Nice job, it looks awesome.
07-30-2010, 08:54 PM | #17 |
A few shots of the interior. I cut up the stock newbright interior to fit snugly around the trans and Axial spur gear while keeping the body as low as possible. A few close up shots of the finished interior. |
07-30-2010, 09:43 PM | #18 |
Rock Crawler Join Date: Apr 2010 Location: America
love it but id try a different rim idk just seems there more scale lookin ones for this build but anyway nice rig truly amazing
07-30-2010, 09:59 PM | #19 |
| I had rc4wd OEM steels on it but the drive pin notch was cut too deep so the wheels rubbed on the hubs. Id love to find some proper steel scale wheels.
07-30-2010, 11:26 PM | #20 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
| Nice build. I had the same issue and contacted RC4WD and they sent me new hubs that were cut right. Drop them an email.
