10-22-2010, 10:26 PM | #1 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| Project F250
A while ago I started a thread in the large scale forum, I decided to put 1.9's under it...and it really wasn't 1/6th scale.... heres the orginal thread Squatch71's F250 I started with mounting the leaf springs...these have since changed..but only the brackets turned 90 degrees...to make the wheels clear when they turn. Kind of mocked up.. Cut my own shackles..and mounted the front leaf springs to frame... Gotta keep puttin the body on......love this thing..duct tape works for holding the body on the frame...pretty good..... Will post more when I get it. thanks for lookin and look forward to the comments |
10-24-2010, 07:36 PM | #2 |
updates. Bent a transfercase bracket, and durafixed it to the frame...I like this stuff Made rear links Tranny mount in the front... Attached the tranny and transfercase made a upper link bracket...love this durafix stuff.... put on the upper links all put together..... another view, you can see the leaf spring mounts where I turned them 180 degrees. No it won't be this tall and have this much travel, in the rear anyway. thanks for looking and look forward to the comments. |
10-26-2010, 10:09 PM | #3 |
Rock Crawler Join Date: Apr 2009 Location: Great Falls
It's looking good, that is going to be a beast. I really like the transfer case mount, very slick setup.
10-26-2010, 11:25 PM | #4 |
Quarry Creeper Join Date: Nov 2006 Location: out in boonies!!
hmm whats this durafix stuff? btw looking good. |
10-27-2010, 09:51 AM | #5 |
thanks Big78...this one, MetalHeads and your Bronco will look sweet next to each other come our anually "spring snow" crawl skinner, thanks for the comment. durafix, lots of vid on utube, heres a link http://www.youtube.com/watch?v=UWb09...eature=related |
11-03-2010, 08:45 PM | #6 |
Update.... Big78 and I had a build weekend, was pretty cool...he got lots done on two of his rigs and I worked on mine... started with this made this stuck it here for this then put that there for these made this for that Now this is the cool part...all put as a "roller" had to put in some flex shots...I think it does pretty good for what it is...and it puts alot of doubts behind. Yes its articulating and yes all three tires are touching the cow mat. the lift is about 3 1/2", can do the same to the front as well..... and thats it........................... Last edited by squatch71; 11-03-2010 at 08:48 PM. |
11-04-2010, 01:47 PM | #7 |
Quarry Creeper Join Date: Mar 2004 Location: North Central Hell, Montana
BITCHIN! Man, you're really Durafux...er....Durafixing the shit outta this bad boy! It makes for a really clean frame dude. I like the way this is coming together. Those front shock mounts are badass! I also like the way you mounted the rear shocks. It leaves you all the room you need to mount the body, even with a dropped bed box. You guys got a shit-ton more fun stuff done last weekend than I did. Looks like it was a good time. I gotta get over next time you guys are building. |
11-05-2010, 01:06 PM | #8 |
More than enough room here my friend..set up on a 4x8 plywood and on the other side are grinders, bandsaws and drill press....Wintertime, might have to move to Big78's...his is heated.
11-05-2010, 08:36 PM | #9 |
11-05-2010, 09:02 PM | #10 |
11-10-2010, 09:54 PM | #11 |
had another build weekend....worked on other rigs, but did touch this one a bit... it is a roller..kinda, had to tweek some things, but works really well. filled in the big hole in the back of the cab. Started sanding. put it on the frame and tried on the 1.9 flatirons. whatcha think??? |
11-12-2010, 09:14 PM | #12 |
gotta vid of it....first run, just around the driveway...taped all the parts on. http://www.youtube.com/watch?v=blLx6BXxJbs |
11-13-2010, 10:49 PM | #13 |
Newbie Join Date: Mar 2010 Location: chilliwack bc CANADA
lol i never buy links ,,homemade links ftw!! |
11-13-2010, 11:11 PM | #14 |
Quarry Creeper Join Date: Mar 2007 Location: Martins Ferry,OH
it looks really wide
11-14-2010, 12:39 AM | #15 |
| yep, I like building my links..you can do what ever size you like. it is a little wider than I hoped, but it is the width of stock axial axles. Don't really want to cut them down, and I can live with the width. |
11-14-2010, 11:20 PM | #16 |
Quarry Creeper Join Date: Dec 2008 Location: Hawthorne, CA
It's coming along good. Your setup looks good, how well does it work?
11-15-2010, 10:12 PM | #17 | |
thanks, Big78 and I built again a bit this weekend..soon as my computer is put back I will down load the pics I took..mounted some thing on the front!!!!!! | |
11-28-2010, 09:31 PM | #18 |
Sooo, Big78 and I were building....moved my computer and just got it up and running so heres some pics of our build weekend. I was thinking on how to mount the thing on the front...he cut this really quick... and then made this and tweeked it a bit clamped on for tweeking still have some tweeking on it...but starting to look good, I raised the body with some body lifts so the tires clear. |
01-06-2011, 06:56 AM | #19 | |
Newbie Join Date: Nov 2010 Location: victorville
01-20-2011, 08:59 PM | #20 |
Thanks man....means alot... heres some on the bay, this is where I got mine. http://cgi.ebay.com/ALUMINUM-REPAIRS...item3f0626bb59 |
