04-01-2006, 01:43 AM | #1 |
Newbie Join Date: Jun 2005 Location: Bundaberg, Australia
| New Jungle Rescue crawler
Hey guys, Thought i'd drop in a picture of my current scale build. Body is from a truck from the bay, TLT axels and a lot of fiddling and building, Still have the wheels to die, ESC and reciever to fit, a few scale bits and pieces to tack on and a few tool boxes to cover the gear box. Fairly happy with the flex so far, will work on it once it is finished. Feedback kindly appreciated. Thanks guys. |
04-01-2006, 05:13 AM | #2 |
Rock Crawler Join Date: Jan 2005 Location: Bethlehem, GA
Hmmmmmmmmm, that looks a lot like my last build a few months ago.... http://www.imagestation.com/album/pi...?id=2123689760 |
04-01-2006, 09:20 AM | #3 |
Quarry Creeper Join Date: Sep 2005 Location: Lethbridge
Umm...................... do the drive shafts work on that angle ? |
04-01-2006, 09:23 AM | #4 | |
04-01-2006, 09:47 AM | #5 |
Quarry Creeper Join Date: Dec 2005 Location: Mechanicsville, VA
I think he's reffering to the orignial poster, as am I. Those DS & axle angles look atrocious.
04-01-2006, 10:08 AM | #6 |
Rock Crawler Join Date: Mar 2004 Location: Albany
Does the suspension move at those angles on its own? Hows the steering? |
04-01-2006, 10:48 AM | #7 |
Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
Those driveline angles are definitely scary. Maybe you should ditch the tires and go with some Masher 2K's and lower it about a 1/2". I think it would look a little better. You could also drop the transmission and link mounts.
04-01-2006, 10:48 AM | #8 |
wow, those are some violent driveline and link angles, sterring, flex????
04-01-2006, 11:18 AM | #9 | |
Pebble Pounder Join Date: Aug 2005 Location: Rochester
04-01-2006, 03:51 PM | #10 |
Pebble Pounder Join Date: Oct 2005 Location: Oregon
I love how everyone says the same thing only in different words..
04-01-2006, 06:46 PM | #11 |
Hey Guys, Thanks for the concern on the drive shaft angles, They all seem to work fine I have angled the diffs a little to help stop the binding, will try to get a flex shot when it's done. It is based on a 1:1 Australian troop carrier and support truck, similar to the merc Unimog, I need the bigger tyres to help it look the same, A little higher than the original but i like to have the center clearance. cheers |
04-01-2006, 09:00 PM | #12 |
Your center clearance is gone anyway; the fenders and steps hang down to the tops of the tires. If you lower the tranny you'll have a lot smoother running without losing any clearance and have a lot more functional truck. Not only will your driveshafts not bind up (and you'll be able to fix that caster angle) but you'll lower your center of gravity by a good inch, and you'll have a place to hang the links so they're not vertical. I know it sucks having to rebuild your whole truck; I've done it myself many times. This truck as it is now reminds me of a gal I used to date. Nice to look at, but I wouldn't want to spend too much time with her. Drop the tranny about an inch and a half and you'll be in much better shape. |
04-02-2006, 10:04 AM | #13 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
Man........
