07-17-2011, 09:33 PM | #1 |
Rock Crawler Join Date: Feb 2008 Location: Georgetown, TX
| SgtSteve's Class 2 JK
Finally decided to post my Jeep here. Here is the build thread from over the last several months. I will post new updates here and @ TXRCRCA.com from now on. While your there be sure to check out all the great Texas rigs Started as a stock Honcho Parts list Body: NB 4DR JK ESC: Holmes Hobbies BR-XL CC BEC set to 7v Motor: Holmes Hobbies Torque Master Pro 540 (35t) ***Absolutely awesome motor*** Servo: HS-7950TH @ 7v Winch Servo: MG946R w/HeyOk HV controller **This controller kicks butt** TX/RX - Futaba 3PM-X 3-Channel w/R603FF reciever Tires: RC4WD 1.9 Rok Lox **Comped with these a few times now and really like them. I would love to get some Nova foams in them eventually. **EDIT** Wheels: These will be going on my Class 1 build now. For the JK, I just picked up a set of LockedUp's 1.9 Trail Ready wheels/rings. Just like the The Scale Shop wheels, these are fantastic. Super easy to mount, very well machined, plenty of hex depth and the perfect offset for this build. The Scale Shop OE 5 spoke aluminum ***Really hard to come by, but If you ever see a set for sale, get them!!! The easiest set of rims I have ever mounted tires to and the overall quality is top notch Batteries: 2200mah 3s from VP Knuckles Axial CVD's with Gunner pins Gunnar "Beef" Toobs in the front axle Axial HD gears (under drive) in the rear axle Krawler Konceptz license plate - yet to be mounted R2J Heavy Duty Pull Pal R2J Kustoms Steel 4 Link Axle Truss on rear axle Hand made parts (by me): Front and rear bumper Servo and winch servo mounts Links Here is how it looks today... New servo mount, winch servo will sit in front of it. Disregard the front bumper here, it was loud stinky brain fart!! Need to redo the electronics mounting but here is how I had it. Interior w/ very little trimming to make room for the trans. Carpet Things to do: Trim the front fender flares a bit more Clean and paint the front bumper, along with installing a fairlead and at least one tow point. Redo front fender wells, have the material just need to trim and paint. Make new electronics box More.....tired of thinking for now I have a lot more pics, and alot more work into this thing than whats posted so if you have any questions on any of it please feel free to ask, I like to share Last edited by sgtsteve; 07-30-2012 at 08:55 AM. |
07-17-2011, 10:18 PM | #2 |
Did you hook up the winch controller yet ?
07-17-2011, 10:45 PM | #3 |
| Sure did. First to the Bulldog winch, worked great, then remembered I had an MG946R Tower Pro that didnt work anymore. Light came on, solder came out, and now I have a great working servo winch. That controller is awesome! Thank you Eric and HeyOk!!!
07-18-2011, 06:37 AM | #4 |
Good deal. Are you going to run bulldog or servo winch ?
07-18-2011, 07:25 AM | #5 |
Servo
07-22-2011, 03:57 PM | #6 |
Quarry Creeper Join Date: Mar 2011 Location: Clover, SC
nice lookin jeep! what links did you use? I saw that it was a honcho but im just wondering what you ended up with. |
07-22-2011, 07:42 PM | #7 | |
For the all the links I used 8-32 threaded rod sleeved with 1/4" brake line and traxxas rod ends. Ended up with the Jeep? Not sure what you mean? | |
07-24-2011, 07:04 PM | #8 |
Got a few things done today: Front bumper painted New rear body mount Painted the rings (great suggestion Cory!) After next weekends comp I plan to make tube shock mounts front and rear along with a new front body mount. Eventually I will get the plastic roll cage out and replace it with a steel one. |
07-29-2011, 06:56 PM | #9 |
Did a little today to prep for tomorrows comp... Re-did the rear bumper to make it a little lighter and fit better given that I also trimmed the fender flares front and rear. Bumper stickers front and rear - now its rockin'! Still need a fairlead |
08-27-2011, 06:00 PM | #10 |
Finally an update.... Got some new sliders done, clean and smooth. Just need to add tubes to them. |
08-27-2011, 06:07 PM | #11 |
Boatsides/sliders look good. It look even better with the tube. |
09-03-2011, 01:47 PM | #12 |
Got the tubes on. Just need paint now. |
09-03-2011, 03:04 PM | #13 |
Pebble Pounder Join Date: May 2011 Location: Vacaville
Super clean man Bad ass rig Justin |
09-03-2011, 05:01 PM | #14 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Great job i think you did a great job. Just in my option, you might want to reverse the angle of the chassis mount. Like this. It make a smoother transition. Just my 2 cents. |
09-03-2011, 06:42 PM | #15 |
Thanks guys. Now that its painted, the transition is pretty smooth. Here it is painted up. |
09-03-2011, 06:57 PM | #16 |
Looks well put together. Nice rig. |
09-06-2011, 08:36 PM | #17 |
Steve came out to the GTG yesterday and is NOT scared to use it. Air time... |
09-06-2011, 10:39 PM | #18 |
Quarry Creeper Join Date: Mar 2011 Location: Universal City, TX
Damn, I wish I had made that trip to Bull Creek. Looks like you guys had a blast. The Jeep's looking good. I hadn't thought about running a servo winch quite like that. |
09-07-2011, 12:15 AM | #19 |
We should have some video soon of the few spots i winched myself and others up some pretty good inclines..holds up really well.
09-08-2011, 05:43 AM | #20 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
one of the cleanest jks ive seen so far. super realistic!! great job. your tubework is great very suttle and not over the top very 1:1!! |
