01-11-2012, 11:14 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Grande Prairie, AB
| Another Tundra Truggy!
Seems like these yota tundras got popular lately.. Anyways, I'm building one too, Had my eye on the Boyer chassis for a while and wanted to put a tundra ontop. The chassis itself is nice but the metal link ends from rc4wd have a lot of slop in them. Going to be changed for some custom links, not to mention I have to extend the wheel base to fit the body ontop. Specs RC4WD Boyer chassis roller Ultimate Yota axles w XVD and 4 links Cast steelies 1.9 black with yota scale lockers R2 1:1 Trans Punisher Shafts TSL boggers Novak Goat 3s Novak 18.5t brushless 7955 Hitec Rc4wd winch9300 LED light bar Photos to come tonight. |
01-11-2012, 11:20 AM | #2 |
RCC Addict Join Date: May 2010 Location: Midwest
| Re: Another Tundra Truggy!
Sounds like a good setup so far. Are you doing the tube work?
01-11-2012, 12:54 PM | #3 |
Well the Boyer is pretty much RTC but I'm going to add either and exo cage or an inner cage to the body and around the front. Got all the supplies coming, Harris safetysilv45 and white flux on order. Picked up the 3/16 brake line (nice green coating included). Started off cutting the body for the dove nose Mocked up the bed plate and battery box out of cardboard Narrowed up! Split and narrowed the grill Loose mount Last edited by jmike; 01-11-2012 at 06:24 PM. |
01-11-2012, 07:59 PM | #4 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
Wow love that narrowed front!! I have not had enough experience with cutting and glueing bodys to attempt that. What glue are you using for that?
01-11-2012, 09:50 PM | #5 |
| Re: Another Tundra Truggy! Plastruct, Inc. - Online Product Detail I dont have a whole lot of styrene time in myself but it really wasnt that hard. I just cut out the section and hit the front quater panels with the heat gun. Then hit it with the bondene. Later i will fill and shape with some body filler once the rest of the streyne work is done. |
01-12-2012, 12:33 AM | #6 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Nice Jmike! Take your time with the body work. It'll pay off in the end. As for the brakeline...make sure you sand the coating off the tubing. |
01-14-2012, 06:28 PM | #7 |
| Re: Another Tundra Truggy! Made a mock up of the cage out of rebar tie wire Brazed it all up Got the cage together Cage together Fitted in the Tundy Waterproofed the Goat 3s while i was tubing Cage with front rock grill and light bar installed |
01-15-2012, 12:03 PM | #8 |
Quarry Creeper Join Date: Aug 2006 Location: On A Big Pile Of Rocks
Looks good,your doing pretty good fab work, keep the updates coming. |
01-15-2012, 01:56 PM | #9 |
Rock Stacker Join Date: Apr 2009 Location: brisbane, Australia
nice looking build, im in love with that light bar. looks like the vision x light bars. dove nose looks tidy, will be keeping an eye on this for sure.
01-15-2012, 07:48 PM | #10 |
| Re: Another Tundra Truggy! Finished up the back of the cab Made up a radiator for the back Also brazed on some tabs to secure the inner cage to the body. Hope my ultimate yota axles get here soon so I can start putting things together. |
01-16-2012, 12:24 AM | #11 |
Jmike...I'm going to press you a little. Do you have diamond screen on the windshield of your 1:1? Why on the scaler? It would drive you nuts on the trail! I like the fans, but the tubing is way out of scale...it scales to about 3 inches...a little big for a cooling system in my opinion. I like the plan...but again I have to press you on this! |
01-16-2012, 02:15 PM | #12 |
Haha thanks bulldog! Keeping me on my toes! Tough to hold back some times and not use what's in front of me. maybe some 13ga wire might work better for the hose. As for the rock grill mesh was thinking about that and am thinking of cut it down half way in the front for a better view. As fOr the headlights I was thinking of using the axial Piaa inside the holes. Outta town for a week or so, will get on the changes when I'm back! |
01-16-2012, 05:42 PM | #13 |
Newbie Join Date: Aug 2010 Location: oakland
looks good so far!what do you think of the Boyer chassis? i just got one but not the full roller.
01-16-2012, 08:04 PM | #14 |
I pieced the parts together on the RC4WD site and by the time you got the axles, tranny, punishers, links, metal rod ends, winch etc the roller was a good deal. But the metal links have a lot of slop and are getting changed out, I upgraded to the ultimate yota axles, and I'm swapping to TSL boggers. So I don't know if I made out that much ahead. That said the chassis it self is bad a$$ and the adjustability is awesome and should be able to accommodate and hold up to multiple builds throughout the years!
01-16-2012, 11:37 PM | #15 |
I was digging around at lowe's today, and saw some electrical wire that could do the trick. It'll hold a bend and look spot on. We'll see what you come up with...and smack you around a little if we don't like it! That's why we're here! |
01-22-2012, 10:23 PM | #16 |
| Re: Another Tundra Truggy! Broke down the Ultimate Yota axles and installed the XVD Filled with Lucas Red n' Tacky Remade the links to get rid of the slop of the metal link end and extend the wheelbase Mock up with the body, wheelbase seems alright |
01-23-2012, 07:49 PM | #17 |
| Re: Another Tundra Truggy! Got a nice little tool box for my battery Thinking of putting the rad at the far back and ditching the spare tire, going to use 12ga wire work the hoses, will conform to a more scale appearance Started the interior MVP is too big, going to look for something closer to the terminator here Everything is loose now, still have to square it all up and connect it to the interior |
01-23-2012, 10:37 PM | #18 |
Everything is looking good. Nice update. |
01-24-2012, 01:05 AM | #19 |
Quarry Creeper Join Date: Oct 2008 Location: Allentown PA
Looks good man, You Are doing almost the same details I wanted to do with mine. How bright are all those LED's?WOW!! Keep it up. Greg |
01-27-2012, 07:18 PM | #20 |
| Re: Another Tundra Truggy! Finished off a little more interior Made some pedals Mounted the rad Used some mesh as a guard The 12awg wire looks a little better Hopefully you can see the drivers feet and the pedals while climbing. Got some a set of box sides coming to to use on the back to give it a bit of a different look. We'll see how it turns out! Last edited by jmike; 01-27-2012 at 07:21 PM. |
Another Tundra Truggy! - Similar Threads | ||||
Tundra truggy class 2 (Pink Taco) | Moosekey | 1.9 Scale Rigs | 87 | 05-09-2015 12:28 PM |
tundra truggy | spyderwebbcustoms | 2.2 Scale Rigs | 14 | 04-09-2012 09:08 AM |
Tundra Truggy | venom-crawler | Axial SCX-10 | 7 | 10-25-2009 10:30 PM |
Sleekster's Truggy Tundra | Sleekster | 1.9 Scale Rigs | 6 | 10-14-2009 03:48 PM |
