Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: best axles for a 6x6 project?
Old 06-23-2012, 05:44 PM   #1
Default best axles for a 6x6 project?
i've got a bug to build a 6x6 rig. got to sell or trade some things off to get parts pulled together but i wanted to get opinions on the best axles to base it off. i'm planning on running 3 link setup, axial tranny at the front with a transfer case.
jebster is offline   Reply With Quote
Old 06-23-2012, 05:48 PM   #2
Default Re: best axles for a 6x6 project?
i would say axial ax/scx axles
theloudone is offline   Reply With Quote
Old 06-23-2012, 06:17 PM   #3
Yep
CrawlinMike is offline   Reply With Quote
Old 06-23-2012, 06:17 PM   #4
X2 on the scx/ax axles they seem to be the best to convert the centre axle for thru drive I think you can do the same with TLT's. There are plenty of thread on here with how to's, if you want to be different you could allways run a dual output transfer and 2 rear tailshaft's to any diffs you like.
greenjk is offline   Reply With Quote
Old 06-23-2012, 06:27 PM   #5
Have a look at SDI axles they will probably be easier
northernerbill is offline   Reply With Quote
Old 06-23-2012, 06:30 PM   #6
I've done it with HPI crawler king axles. Driving on it more than 1.5yrs now.
Old 06-23-2012, 06:47 PM   #7
Jeep whore
scale4x4's Avatar
if you have money to burn, you cant beat the blackwell's.
scale4x4 is offline   Reply With Quote
Old 06-23-2012, 07:39 PM   #8
Thanks for the inputs. I was looking for the best value solution. Seems like the scx axles would fit the bill. I will be reading through the threads on this, especially how to make the center axle.
Old 06-23-2012, 07:43 PM   #9
scx10 axles are your best bet like as everyone else mentioned. i know my lhs sells them periodically for 40.00/per axle NIB. usually they tear apart new kits to sell parts to the customers.
ive never done a 6x6x6 setup myself but....couldnt you use x2 front side of the axle so the pinion exits both sides to power the last axle in the rear? just a thought?
x2 of the same top part of the axle in pic?
SwampDawg is offline   Reply With Quote
Old 06-23-2012, 09:03 PM   #10
SCX axles are easy to mod, basically you just need a front case half and an extra pinion.
jmz6 is offline   Reply With Quote
Old 06-23-2012, 10:37 PM   #11
Its easier to just get an extra axle, so if you want a 6x6, get 4 axles. You can try and see if somebody will sell you an extra pinion and shaft in the wanted section.
Multi-axle rigs are fun!
DrunkDriver is offline   Reply With Quote
Old 06-24-2012, 12:20 AM   #12
one day id like to do a military 3-axle rig...hmmm!
so many projects, so little time.
Old 06-24-2012, 04:07 AM   #13
i've been thining about this type of project for awhile. trying to trade off my summit to get started. (love the summit but not getting much use out of it).
i've been looking through other build threads and here are some examples of rigs that caught my eye:
Old 06-24-2012, 07:42 AM   #14
For the ax 10 pass through axle you need two of the output side cases and two outputs. The pass through axle will sit with one axle half facing up and the other upside down, the half facing up will be tward the front of the truck and the half facing down will be closer to the rear axle. Then the rear axle will be flipped or mounted upside down because its output will spin the opposite direction.
ctrwannabe is offline   Reply With Quote
Old 06-24-2012, 09:27 AM   #15
i appreciate the input. i was thinking about the rotations of the axle input/output shafts. this clears it up for me.
Old 06-24-2012, 11:10 AM   #16
the output shaft from the middle axle that powers the rear axle spins in the opposite direction so the rear axle must be flipped upside down so that the tires turn in the correct direction.
I build a 6x6 a few years ago using the ax-10 axles, it was pretty easy. I actually liked the look of the WK axle housing better, they looked more like a Rockwell style military axle but parts for them are much harder to find.
BigSki is offline   Reply With Quote
Old 06-24-2012, 11:12 AM   #17
yep 2 of the same. add your pinion gear in the axle and you're good to go.
Old 06-24-2012, 11:37 AM   #18
i had thought about the WK axles too and for the same reason (the look) but i think parts and price for scx10 axles will be the best. it does make me regret selling my WK foff project a few months back!
Old 06-24-2012, 02:03 PM   #19
If you want a true 1:10 scale model, you may want WK axles to bring the width into the right size.
Figure out what truck you want to build, and figure out the scale. Wide offset wheels may get you what you need, but you often won't get the nice scale stuff. Really, a true 1:10 scale multi- axle rig should use 2.2 wheels/tires.
The poles have proven this, just check out this forum:
Google Translate
Old 06-24-2012, 02:36 PM   #20
Google Translate
i haven't done enough research on sizing things up yet. chances are i won't be as true to scale as others. i'm hoping to get something that looks close to scale while still using readily available and hopefully inexpensive parts. going to be looking at the for sale section quite a bit!
best axles for a 6x6 project? - Similar Threads
Project overkill 6x6 CaptainSafety 2.2 Scale Rigs 22 02-18-2011 09:18 AM
my vmg 6x6 project mike Tamiya TLT Crawlers 9 01-31-2005 11:27 AM
