07-16-2012, 11:16 PM | #1 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
| Class 1 Scout (Another aluminum body!)
This is something i started a while back but just now got to post it. I had this SCX10 based scaler i acquired some time ago. I'm not sure who built it but it was a good truck and i wheeled it a lot but it was very heavy and fell into class 2. Since I already had my Toy for class 2 I decided I needed something for class 1. Here is how it sat before i started Now i had a new body that came with the truck and after placing it i realized the wheelbase was off After some new links I had the wheelbase i was looking for I also removed the cage With a clean chassis i started on the new body. Of course, me being me, I couldn't just use the lexan body and since I've been wanting to try making molds from a lexan body i gave it a go. the process is fairly strait forward. pick a section of the body and make a dam pour the resin right into the body and pop it out Then I cut along the hood lines and after some cleaning made a test panel Then i repeated the process I did the side panels in 2 pieces and then trimmed them I fitted the front to the back Then trimmed out the door and rocker. There is still some trimming and sanding to do but it's coming along Oh and here are the grill and rear tail sections. they came out good as well. More later |
07-16-2012, 11:30 PM | #2 |
I'm HUGE in Japan! Join Date: Dec 2011 Location: Clearwater - home of the endless summer
| Re: Class 1 Scout (Another aluminum body!)
The master @ work.....
07-17-2012, 12:31 AM | #3 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
This will be amazing......
07-17-2012, 01:14 AM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: australia
Very nice start i will be watching this build for sure cant wait to see the panels..
07-17-2012, 01:31 AM | #5 |
MODERATOR Join Date: Oct 2010 Location: RC Land
Two questions if I may... What is the resin you are using? How thick is the aluminum that you are forming? Awesome idea & nice work |
07-17-2012, 01:51 AM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Another place, another time
Well, you definitely got my attention. |
07-17-2012, 02:49 AM | #7 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
OMG....that is a awesome work. I would like to see more details...tell us how u made that work |
07-17-2012, 06:39 AM | #8 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
all i can say is " " speachless!
07-17-2012, 09:27 AM | #9 |
Rock Crawler Join Date: Feb 2008 Location: Copperopolis
| Re: Class 1 Scout (Another aluminum body!) |
07-17-2012, 09:30 AM | #10 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
In extreme awe! X2 with what THX_138 said! Last edited by 17dean; 07-17-2012 at 09:31 AM. Reason: spelling! |
08-25-2012, 10:28 PM | #11 | ||
| Re: Class 1 Scout (Another aluminum body!) Quote:
The material is Tooling foil found at art supply stores like Dickblick Pure Metal Tooling Foil - BLICK art materials Quote:
Thanks guys. This project may be a little slow. I'm working on other stuff right now but i did get a little progress. I started by trimming the front grill Followed the body line on the side Then the bottom and top where the hood was Then i wanted to do a test run but i quickly realized my typical method of forming was not going to work The draw was so deep i couldn't get it to pull without folding so i had to go a different direction I started with an impression then i flipped it over, placed it on a soft surface and began stretching the metal close to the shape of the grill This allowed me to draw the metal further around the grill And after some more work i had the look i was after with very little folding Here is the final result Then i repeated the process for the rear corners Oh, and i couldn't resist testing some rock rash This truck is going to be fun | ||
08-25-2012, 10:54 PM | #12 |
RCC Addict Join Date: May 2010 Location: Midwest
Looks great How fragile exactly is that foil? Are you going to construct a body using just that or ?? How will you attach the pieces of aluminum to each other? |
08-25-2012, 11:29 PM | #13 |
I wanna be Dave Join Date: Jul 2007 Location: Within The Machine,,,
Blake,,,I still Dont Believe Your Not a Wizard....
08-26-2012, 12:57 AM | #14 |
So far, so awesome. |
08-26-2012, 11:15 AM | #15 |
Quarry Creeper Join Date: Mar 2011 Location: Universal City, TX
Wow. I am subscribing to this one for sure. |
08-26-2012, 11:52 AM | #16 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
thanks for providing the materials list. Might have to tinker with this process myself subscribed
08-29-2012, 11:13 PM | #17 | ||
I've already made many trucks with this method and it works file and is very realistic. Here are just a few Project true scale - Aluminum Toyota body! Joe's flatty The revival! Leo's Willy! old comp truck turned scale truck (the rebuild!) You never know Quote:
I got a little progress on the body I finished the grill mold by drilling out the head lights and using a drill press with an X-Y vice and a milling bit to open up the grill opening Then i drilled out the rear corners for the tail lights The cool thing is the roll bar light lenses from the high lift fit perfictly Next i finished shaping the metal and tested the fit of the lens Then i test fitted the panels together starting with the rear quarters Then clamped the rest of the panels together so i can start figuring out how to do the rest of the inner panels And a quick test fit on the chassis Not too bad. But i need to do something with the tranny. It's not going to cut it in there That's next on the list | ||
08-30-2012, 07:48 AM | #18 |
Good stuff, as always. Have you considered goop-ing ( new word??) styrene for the inner panels? This would give some rigidity to the panels and leave a surface that would be easy to add details to.
09-03-2012, 02:27 PM | #19 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
Wow you make this process look so easy Metal body looks really good subscribed to see your progress.
09-03-2012, 02:42 PM | #20 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
ha cool!! I want a aluminum BRAT body cant wait to see smashing videos!! remember the old jeep vid |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/393522-class-1-scout-another-aluminum-body.html | ||||
Land 109 Serie III Full alu | This thread | Refback | 02-21-2013 04:16 AM |
Class 1 Scout (Another aluminum body!) - Similar Threads | ||||
2.2 scout body | crf250x | Paint and Body | 11 | 06-10-2010 09:24 PM |
looking for Scout II or Scout 800 body | oldblue | Paint and Body | 6 | 05-08-2010 08:25 AM |
Scout II Body??? | o3_xterra | Paint and Body | 4 | 11-06-2009 11:36 AM |
I need a scout body | speedemall | Paint and Body | 10 | 11-28-2008 05:25 PM |
