04-11-2015, 07:37 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Mattzilla Ultra4 1.9 "Rising Sun"
This is what the built is based on.... Mattzilla U4 chassis in Orange, thanks Lue for this excellent chassis... Rest of the components.... Front Axle XR Beef tube - One of the very original one, steel with no spline; TopCAD Chub - with a long set screw to lock it in place onto the tube; Vp Wraith knuckle; Axial XR-10 Uni shaft; Axial HD diff gear; Front diff with 500k diff oil; HR upper link mount; Rear Axle Same old style xr-10 tube; STRC lockout; Custom Creeper Bob Ti shaft; Axial HD diff gear; Gripfab spool; GCM upper link mount; Drive line MIP drive shaft, front cut to suit; Built Tranny - Supershafty motor plate, top shaft, Robinson 56T 32p slipper, idle gear, one piece final gear, 15T pinion; Some random Chinese alloy housing; Suspension Kyosho Red Velvet shock with rod end and diaphragm mod; Tunigy spring that I have; Home made link (3/16" black 6061 rod with RPM rodend); Wheel Tyre Duuuuuuude delrin rim with lockedup RC bead lock ring and scale hardware; RC4WD Gladiator tyre; CI Deuce wild foam with a layer of foam; Electronics Traxxas ET-3S ESC flashed to MMP; Tekin Gen2 Redline 13.5T motor; Castle BEC; Tunigy TS-910 Servo; Chassis Mattzilla Ultra 4 in orange; HPI Apache interior; Axial Yeti Fuel cell; Random Spare tire; Some Random pic.... I have not had a chance to run it...due to the rain..... Its ready for panel, I think it will have 0.5mm Alloy panel. Not sure of the painting scheme yet. Tell me what you think... Last edited by Colgout; 04-11-2015 at 08:05 PM. |
04-11-2015, 08:16 PM | #2 |
Quarry Creeper Join Date: Mar 2013 Location: Wisconsin
| Re: Mattzilla Ultra4 1.9 "Rising Sun"
Looks awesome, Can't wait for some action pictures! What did you do to the beadlock rings? I've never seen that done before and it looks pretty slick.
04-11-2015, 09:06 PM | #3 |
Just spray some etch primer and then Red paint, and splatter some yellow paint on it. Nothing special.
04-11-2015, 09:44 PM | #4 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Looks pretty good. Haven't seen one that color yet. I like it. |
04-12-2015, 10:17 AM | #5 |
Harley? orange: check Tekin motor: check splatter: check |
04-12-2015, 10:59 AM | #6 |
| Re: Mattzilla Ultra4 1.9 "Rising Sun" |
04-13-2015, 06:34 AM | #7 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
Looks nice, ready to see some action pics of this one. Wes |
04-13-2015, 08:49 AM | #8 |
04-16-2015, 10:48 PM | #9 |
04-16-2015, 11:04 PM | #10 |
Quarry Creeper Join Date: May 2010 Location: Perth, Australia
Looks good.. our MZ 1.9s share a bond between each other in the orange stripe |
04-17-2015, 07:06 AM | #11 |
Newbie Join Date: Mar 2015 Location: Warnbro
Looking great love thw colours and those panels shouldnt dent to easily 😃. Looks like i may be able to make next race now. Electronics should be back in time.
04-17-2015, 10:06 AM | #12 | |
| Re: Mattzilla Ultra4 1.9 "Rising Sun" Quote:
The bonnet wont dent, it was 1.5mm ali plate, all other panel is only 0.5 ali and will dent bent quite easily..... I kinda like the color combination too, I am make new panel for my pro righ with the same color scheme... | |
04-18-2015, 09:58 AM | #13 |
05-03-2015, 10:35 AM | #14 |
Some update, had 1 race today and had a lot of fun....... Next time I will stay whole day.... I think the Twin Hammers is quite worry what's behind her......lol Last edited by Colgout; 05-03-2015 at 11:03 AM. |
05-03-2015, 11:01 AM | #15 |
I changed out to a RevTech 4 poles 3800 Kv motor because I thought the tekin Gen2 Redline 13.5T was too slow.... The Revtech is a lot faster, but I found out today, I barely used full throttle and the Tekin may have been suffice. I will try to put it back for next race and see how it goes.
Mattzilla Ultra4 1.9 "Rising Sun" - Similar Threads | ||||
Mattzilla Ultra4 2014 build from down under - codename "Gojira" | mce076 | 1.9 Scale Rigs | 86 | 04-13-2015 08:38 AM |
*WARCRC* Presents 2012 "Scale" Comp# 10 (Sun. 10/7/12) | justinart24 | Washington | 0 | 10-06-2012 01:40 PM |
SUPER TUBER NAMED TSR-"tequila sun rise" | AxialJeepster | 1.9 Scale Rigs | 15 | 07-22-2012 08:12 PM |
*WARCRC* Presents 2011 "Scale" Comp# 6 (Sun. 9/25/11) | justinart24 | Washington | 0 | 09-21-2011 10:26 AM |
