02-27-2016, 10:21 PM | #1 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| F-Zuk Its about time I start this, only been beating on this chassis for well over a year. This is only the 4th or 5th rebuild I have tinkered till my finger tips went numb.... 4 link front, axle mounted servo, and the ToyZuki motor mount... Ohh and BTA steering. Front Axle: BoomRacing steel case (for weight) DCW Upper link mount DCW wraith servo mount RCBro servo post and clamps RCBro Brass beeftubes XR10 Unis VP Clamping Cs VP Wraith Knuckles RCBro steering arms VP Shock Razors Rear Axle: Axial case (for now) Stock shafts GCM upper link mount Ally Chubs (lathed smooth) VP Shock Razors VP HH BRXL HH 400 Puller Hitec servo KMS Winch (I will upgrade to a freespool at some point) Castle BEC |
02-27-2016, 10:30 PM | #2 |
| Re: F-Zuk
I originally built this for the OK RC4WD Champs. Threw it together in about 2 weeks with a honcho body, steel back half and such. It was right around 5lbs and I beat it like a rag doll. It had an Ally cage that was getting beat up and I was never happy with the overall stance or weight placement. Then I took it to Utah..... Them Utards are mean... So I wanted a tube design that was still some what light up top but overall I could adapt it to any body. Like an F-Toy |
02-27-2016, 10:38 PM | #3 |
| Re: F-Zuk
Because of the front 4link and the motor and drive shaft wanting to share the same place, getting this pig to belly dragger status was an endless game of changing things till I got it where I wanted. It can now sit just below 2in at the front of the skid and still have full steering throw. I am most likely going to shorten some scx10 shocks for the final rebuild, scale power strokes in the rear both on losi miniT springs and limited/strapped to my liking to control unloading. Now the fun part! Can I melt my finger prints off before I finish the cage? |
02-27-2016, 10:56 PM | #4 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: F-Zuk
I guess all my toy trucks are obsolete and too tall. |
02-27-2016, 10:58 PM | #5 |
| Re: F-Zuk |
02-27-2016, 10:58 PM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: F-Zuk
Crazy stuff |
02-27-2016, 11:06 PM | #7 |
| Re: F-Zuk |
02-28-2016, 09:42 AM | #8 |
Rock Crawler Join Date: Dec 2012 Location: Utah
| Re: F-Zuk
Looking good. ..now get it done!! |
02-28-2016, 09:53 AM | #9 |
| Re: F-Zuk
Less explaining... More building. |
02-28-2016, 02:10 PM | #10 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: F-Zuk
Cool! At least you're building it out of metal. Excited to see how this turns out.
02-28-2016, 03:12 PM | #11 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
| Re: F-Zuk
What did you do for a front driveshaft to keep it from hitting the actual motor? I'm having the same problem and I like to have mine belly dragger status too
02-28-2016, 06:18 PM | #12 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Re: F-Zuk
I love belly scrapers |
02-28-2016, 10:15 PM | #13 | |
| Re: F-Zuk Quote:
SDI driveshafts Just found these also but havent used them... hotracing drive shaft | |
02-28-2016, 11:19 PM | #14 |
| Re: F-Zuk
Got some work done... While trying to tuck 1.9 LURC rims over wraith knuckles I needed to either countersink the steering arm screws or this..... Washer brazed to 3mm set screws. Cage Work!! I made this setup table long ago, works a charm to setting right angles and such. I am trying to avoid using welded nuts as much as possible. Zip ties and duck tape... Now we have a base to build from. Solid rod and square stock. The square stock is drilled to be tapped for 2mm scale bolts. |
02-28-2016, 11:36 PM | #15 |
| Re: F-Zuk
Bottoms set, time for the top.... And a little mock up to get an idea of the scale... I need to figure out a few size and placement issues before I burn it in. I made it on the smaller side, sitting at 6.5in wide and 4.5in high. Left the body lines square vs angled with the skid and the usual 12.5wb. With this I can set my track width 10in to 9.5in and still be legal.... still debating that part also. |
02-29-2016, 08:14 AM | #16 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: F-Zuk
Once again I am loving your build. Nice Job !!!!
02-29-2016, 04:52 PM | #17 |
| Re: F-Zuk
looks amazing so far. So low slung.......STANCE
02-29-2016, 07:58 PM | #18 |
| Re: F-Zuk
Sometimes I think you know what you're doing. Looks sick. |
03-01-2016, 10:52 PM | #19 |
| Re: F-Zuk
A local buddy cuts delrin on the side, VaderProducts and Ive always wanted a smaller skid.... I will most likely cut even more material off and then round the bottom edges Then just because... Also drilled and tapped the motor mount to also hold the winch. Now routing the winch line will be so much fun. More cage work in the next couple days. |
03-05-2016, 11:13 PM | #20 |
| Re: F-Zuk
I fought this back end for what seems like forever... I tried the normal rear hoop, tapered, flat bed, blah blah blah Finally pulled the trigger on a simple 2 angled bars. Simple and straight forward, which was the plan for the whole truck. Ill add the rear down bars, cut the shock mounts off the frame and weld some on tomorrow. |
F-Zuk - Similar Threads | ||||
Shauns Zuk | Shaun | 1:1 Full Size Vehicles | 4 | 12-02-2013 12:20 PM |
zuk | oahuzuki | Videos! | 0 | 02-05-2013 06:19 PM |
Zuk build | clutch | Losi Micro-Rock Crawler | 3 | 01-24-2010 07:20 PM |
For you zuk guys | crash | Chit Chat | 4 | 09-29-2009 10:18 AM |
My Little Zuk | RXcrawler | 1.9 Scale Rigs | 14 | 01-09-2009 09:49 PM |
