03-02-2007, 12:29 PM | #21 |
RCC Addict Join Date: May 2006 Location: Roseville
Nice start Diaz. I cannot wait to see how it ends up.
03-02-2007, 12:56 PM | #22 | |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Here is a pic of the rear suspension. | |
03-06-2007, 05:22 PM | #23 |
I joined the Band! Join Date: Mar 2006 Location: Gardena,Ca.
well i decided to run this truck without leafs. so i drew up the rear links today. i need to cut them out and try them now
03-06-2007, 06:30 PM | #24 |
You going to do the radius arms up front?
03-09-2007, 11:06 AM | #25 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
Good choice on the suspension. That should turn out pretty slick.
03-09-2007, 11:41 AM | #26 |
anyone have a pic of a radius arm? |
03-09-2007, 12:12 PM | #27 |
Here you go, the pointy end attaches to the chassis with bushings on it, and the other end attaches to the axle at two points.
03-09-2007, 12:17 PM | #28 | |
RCC Addict Join Date: Feb 2006 Location: UrAnUs
diaz hook me up witht he new design man | |
04-08-2007, 12:39 PM | #29 |
well i got around and made a new chassis. i think this one will work out just great. i'm going to 4 link the whole truck , maybe ;) don't know if i should run leafs in the front. here's a couple more pics
04-08-2007, 12:59 PM | #30 |
Rock Crawler Join Date: Jul 2004 Location: Salt Lake
Looks like you're off to a pretty good start. Nice jorb.
04-08-2007, 09:31 PM | #31 |
4 link it man save you the trouble, or dampers with separate coils?
04-08-2007, 09:38 PM | #32 |
Rock Crawler Join Date: Feb 2007 Location: CoMo...Kickin it with Holmes Hobbies
looks cool, so are you not going to run the radius arm, it be trick if you could.
04-08-2007, 09:41 PM | #33 |
Looks great David, send mine yet? |
04-08-2007, 09:51 PM | #34 |
hey unimog , i have a chassis similar to this one shown if you want it. the center of the frame is not as low as this one shown
04-08-2007, 09:52 PM | #35 |
how does the radius arm pivot in the front if it is attached at 1 points up front. i see how the rear of the arm pivots but not the front. |
05-09-2007, 08:20 AM | #36 |
Pebble Pounder Join Date: Apr 2007 Location: Near Oxford, UK
defenders have coils front and rear. it then has a panhard rod and radius arms at the front. at the rear it has an A frame and trailing arms it doesnt pivot on the axle, when lifted or when the suspension is flexing, the castor angle changes hope that helps. Landy-Ross |
05-09-2007, 08:22 AM | #37 |
any pics?
05-09-2007, 09:00 AM | #38 |
ill get some when i get home from school |
05-09-2007, 09:06 AM | #39 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
although there was once a special that was only used in the military that was leaf because of it being easier to maintain and i saw it on tv on a programme called crafty tricks of war.
05-09-2007, 02:20 PM | #40 |
this picture shows the rear, it shows the top mounts for the A frame. this shows the axle mount for the A frame on the right of the diff pan, this is upside down and also the diff pan isnt standard. the sivler bit in this picture is of a trailing arm (rear by the way) this is of the A frame set up shout if there is anything else you want pictures of Landy-Ross ;) |
