09-14-2021, 12:20 AM | #1 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Wroncho-esque VS410
Here it is-my Wroncho-ish VS410 build. Using a mix of brands and parts not made to go together, so this oughta be an interesting build. My original idea was to do this build with Capra axles, but I couldn’t pass these up. It’s rare to see complete axles for sale here, especially for a good price. I’ve been wanting to do a ground up custom build for a while now, I guess this kinda counts?? Starting parts list: AR60s with brass knuckles/diff cover VS410 Chassis kit SCX10ii 3 gear tranny Element Enduro shocks 1.9 Hyrax Chinesium knockoffs Injora Wraith link kit Injora beadlocks 155mm driveshafts Crawlmaster 10T Reedy ESC Sendero servo Sendero TX/RX I opened up the axles to check the gears/grease, and was pleasantly surprised to see beef tubes in both front and rear axle. The front axle has brass knuckles, diff cover and beef tubes. Around 9.5 ounces of brass on the front. After seeing the front axle, I had to look at the rear- it also has beef tubes. Both axles weigh in at 2.2 pounds. Last edited by ScaleLifeNewbie; 09-27-2021 at 08:58 PM. |
09-14-2021, 12:22 AM | #2 |
| Re: Wroncho-esque VS410
As of now I have got the chassis kit built and got the rear axle hooked up. Having some problems with the geometry though, so I'll have to re-work it. I'll try an snag some pictures of the rear tomorrow Last edited by ScaleLifeNewbie; 09-14-2021 at 12:26 AM. |
09-14-2021, 02:21 PM | #3 |
| Re: Wroncho-esque VS410 https://postimg.cc/Z9Gytfsh Here's a picture of the rear links. If I leave it this way, the driveshaft angle is pretty bad, if I flip the skid, it'll give me a straight shaft, but the link doesn't clear. Uppers are the VS410 Drag/panhard link with Jato ends. Im going to play with some links, but I may have to make my own link(s) |
09-14-2021, 07:23 PM | #4 |
i think you have a issue there ether the pumpkin is on the wrong side and needs to be fliped or the tranny needs to be mirrored those shafts are at a hell of a hard angle i should have read the whole thing lol you need to make custom links they sit at extreme angles but it all works out Last edited by ferp420; 09-15-2021 at 07:02 AM. |
09-14-2021, 07:53 PM | #5 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
A wraith skid is much wider and longer than a vs410 skid, so your links are all squeezed in at the chassis, and they're too short. You can't flip the skid because, like you said, the links will be in the way. To get away with the diff being on the opposite side as the trans output, you need longer links to soften up the driveline angles. Here's my wraith skid, so you can see the difference.
09-14-2021, 11:09 PM | #6 |
Thanks guys for your help. I ended up playing with them for a couple hours and I think this'll work. Still not perfect shaft angles, but not as bad as the previous setup. Everything spins freely, so I'll try this for now. I have a 4 link up front with CMS, but I'm on the fence about getting an SOA mount. At the end of the dsy though, I probably will end up making some links as they do kiss the rails on full compression. This is part of the fun though, trial and error! |
09-16-2021, 04:03 PM | #7 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
Are you able to flip the skid so the drive shafts are in line with the pumpkins? Sent from my SM-G991U using Tapatalk |
09-16-2021, 04:45 PM | #8 | |
| Re: Wroncho-esque VS410 Quote:
I disassembled it to play with it some more to get better geometry. I'm waiting on my SOA mount so that way I can set her up properly. | |
09-22-2021, 01:13 AM | #9 |
Well, I couldn't leave it how it was, so I changed it again and I'm really leaving it here this time. Im using all Wraith links, no custom links. Using a mix of TRX4, SCX10ii and Jato ends. Also using the Vanquish AR60 SOA with 4 link up front, this setup is so much smoother and cleaner than the 3 link CMS IMO. I did have to chop up the front brace for the servo to tuck up in since I want a low ride height. The wheelbase is right at 14.3"; a little longer than I wanted for the body choice, but if all else fails I can just change the body up and shelf it for another build. With the WB being this long, I did have to chop the drop down on the rear of the rails. I really didn't want to, but at ride height the axle made contact with the rail. I also cut the rear of the chassis brace from the fuel-cell rearward, so I'll have to get an RX box as well. Or stay out of the water (Yes I kept the lid) The driveshafts are a little wobbly and maybe a little too short, but they'll hold for now. I'll get some pictures tomorrow after work Last edited by ScaleLifeNewbie; 09-22-2021 at 01:42 AM. |
09-22-2021, 03:31 PM | #10 |
Is it possible to shorten the WB to 13.9", stock Wraith length? Sent from my SM-G991U using Tapatalk |
09-22-2021, 08:28 PM | #11 |
| Re: Wroncho-esque VS410 |
09-22-2021, 08:29 PM | #12 |
| Re: Wroncho-esque VS410 https://postimg.cc/gallery/3vy7719 Don't mind the rough edges in the rear, I still have to do some sanding. |
09-24-2021, 01:39 PM | #13 |
Hoping to get the rig out this weekend for a shakedown run. I'm so very eager to drive this puppy. With a quick run out on the lanai and flexing on some chairs, she seems very planted. Between the wide axles and all that brass, I kind of expected it. But it still surprised me. On the bench it seemed to have less articulation than my other rigs, but the wide axles really make up for it. I also ordered some 165mm shafts so I can get a little more bite than the ones on it now. |
09-27-2021, 08:41 PM | #14 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Have you considered flipping the trans so the outputs are on the same side as the diffs? Would help with the angle and shorten the distance, possibly enough that you wouldn’t need new drive shafts. You will lose the forward oriented motor position, but may be a worth while trade off Sent from my iPhone using Tapatalk |
09-27-2021, 08:57 PM | #15 | |
09-28-2021, 08:55 AM | #16 |
that geomitry looks horable it could just be the way the picture was taken but it looks bad i think you need new links to make this rig work vary interested in how it works in the real world though get video lol |
09-28-2021, 01:21 PM | #17 | |
I'm still going to run this link setup until I can get a proper crawl and see how she does. | |
09-28-2021, 04:00 PM | #18 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Ive got that same set of links, came on a wroncho build i bought from a member iirc. They worked fine for me. SLN, do u have the plates that gonon tge outside of the chassis with multiple upper link mounts? That would help u clock the axles, plus it would raise the upper link just a tad as well. Which would help with driveshaft clearance to the upper link. Ive got a set somewhere. Uf u can find them ill post a pic so u get an idea of wat im talkin about
09-28-2021, 04:12 PM | #19 |
These are the link plates i was talkin about Sent from my SM-A516V using Tapatalk |
09-28-2021, 04:48 PM | #20 | |
Wroncho-esque VS410 - Similar Threads | ||||
VS410 Question? | byrnieman | 1.9 Scale Rigs | 2 | 05-13-2019 07:17 AM |
Mat's Landy-esque Dingo | mat | Axial SCX-10 | 4 | 06-12-2012 12:13 PM |
