Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Project Lasernut for cheap
Old 01-06-2023, 11:26 AM   #1
Default Project Lasernut for cheap
Hello!
I like 1/9 scale rigs (scx10, trailfinder etc are actually 1/9-1/8.5 scale) and think about rock racer for a long time.
When i saw zd racing dbx-10 for a first time, i thought it reminds me armada engineering lasernut ultra4, but it looks toyish. Losi lasernut is much better, but it is too big and its proportions are off too.
Then i found out 1/1 lasernut dimensions and got a plan to rework dbx-10.
1:1 lasenut
wheelbase 3000mm
width 2286mm
dbx-10
wheelbase 290mm
width 265mm
Also i measured dbx-10 and lasernut photos - dbx-10 cage is something like 1/9
So i decided to buy the cheapest one for near 130$ and rework it.
dbx-10 side view:
What dbx-10 dimensions are off:
1) Wheelbase is too short. I made new deck, wheelbase is +15mm for front axle and +20mm for rear axle. Deck is styrene now, maybe i will make aluminum one.
2) Cage is too low, rised it for 23mm front and 17mm rear
3) Reassembled front and rear suspension. Shocks are inside wheelbase now. I put in front something like hpi monster shocks. They have more travel (100mm length) and they are thin, so i dont have to rework steering. It fits perfect.
What i got now:
All dimensions i get are just perfect, just +- few millimeters from what i predicted.
Next steps:
Throw in trx-4 transmission with brushless electronics. Going to use ezrun-sc8 + tensock rc906 1750kv. But if i will not be satisfied with low speed control, ill buy QuicRun Fusion 1200kv
Maybe put scale 1.9 wheels and tires for better crawling (thats why this thread is here).
Pagu is offline   Reply With Quote
Old 02-05-2023, 07:01 AM   #2
Default Re: Project Lasernut for cheap
Compared different electronics smoothness on the lowest throttle (subtrim):
  • ezrun wp 80a + 1150kv outrunner + 2s lipo gives ~10 rounds per second
  • blheli32 + 1150kv outrunner + 2s lipo ~ 2 rounds per second
  • QuicRun Fusion SE 1200KV + 2s lipo ~ 0.5 rounds per second
Sensorless hobbywing esc is not very smooth.
blheli32 is pretty good, i didnt flash it to am32.
With fusion you actually dont need 2-speed transmission at all even on rock-racer.
Not sure what to choose... Maybe fusion with 2s or 3s with 1-speed tranny, because 2-speed has a slop i dont actually like.
blheli32+outrunner would be ok on slow leaf-spring truck.
Old 02-05-2023, 09:28 AM   #3
Nice work, cool looking buggy!
Would like to see a video of it running when it's done!
Thorsteenster is offline   Reply With Quote
Old 02-05-2023, 02:55 PM   #4
Slow is the new Fast
smog's Avatar
Good Idea, the Lasernut is a great looking buggy.
Get crazy with a Mamba X with a Sensored Castle motor. Smooth and Fast alway a blast...
smog is offline   Reply With Quote
Old 02-06-2023, 09:34 AM   #5
Yeah i like how the Lasernut looks too.
It would be great to throw in portals, but i dont want to overcomplicate this project.
Suspension works very good. Proper stiffness, very smooth and good travel.
Dropped it on the floor from 1 meter height and got completely no bounce.
Installed hw fusion 1200kv, copy of traxxas 2-speed transmission and 2s lipo:
I calculated max speed, its near 22 km/h on the 2nd gear and 9 km/h on the 1st gear.
It has pretty good low speed on the 2nd gear and crazy on the 1st gear. I think i dont need so slow crawling.
Going to use 1-speed transmission. It has no slop and it is good to put away one excess servo.
Scx-10 transmission gives too much of reduction, so i will try to put back stock one (just a central shaft with spur on it and a mount for motor with pinion).
Old 02-26-2023, 01:36 AM   #6
Hello! Made some updates.
As i installed longer deck (wheelbase is +15mm for front axle and +10mm for rear axle now), i made longer central shaft. I used 5mm steel brake line tube and 2mm steel rod for pins. Rear end is just cut, front end has this shape for smooth work:
Here is installed new shaft and old one. Also i reinforced deck to make it more rigid:
Also made new steering. It is not flawless setup, but it works. Will rework it if needed:
Old 02-26-2023, 03:07 AM   #7
Maybe its me but I dont get the intension of this build ??
themountain is offline   Reply With Quote
Old 02-26-2023, 08:46 PM   #8
My goal is - scale rock racer Armada engineering lasernut. I correct look and proportions of very cheap model and tune it for better crawling. Suspension travel and low speed control are very good now.
Maybe someone on low budget will find this thread useful. Nothing special, i understand that experienced forum users will not find it interesting.
Old 02-27-2023, 06:15 AM   #9
Why would anybody want a rock racer to crawl ??
Budget ?? 200$ car +120$ body+ 100$ electronics ?? Why not buy the original for a bit more ??
Old 02-27-2023, 08:07 AM   #10
Because the Losi Lasernut is terrible?
DrIsotope is offline   Reply With Quote
Old 02-27-2023, 10:28 AM   #11
I think rock racer should crawl over big rocks. Am i wrong? I dont mean competition crawler for sure. And its not competition rock racer. Its a scale hobby rock racer.
Car is 135$ (brushed version), esc+motor HW fusion is 65$ (aliexpress sales + coupon).
120$ body
I have no idea what are you talking about.
What is original? Losi? Maybe it is not bad basher. But it is 1/8-1/7 model and has wrong proportions compared to real lasernut.
I want scale looking lasrnut close to 1/9, because scx10 and others are near 1/9.
Tags
dbx-10, lasernut
Project Lasernut for cheap - Similar Threads
1.9 Lasernut moon buggy distinctive pd 1.9 Scale Rigs 39 08-15-2022 12:30 AM
Lasernut U4 2.2 farmjohn42 General Crawlers 4 10-05-2021 02:04 PM
New Losi Lasernut U4 RTR? 4RunnerKid General Crawlers 110 02-01-2021 10:25 AM
Project cheap Jeep jj650 1.9 Scale Rigs 19 07-22-2019 11:40 AM
