10-04-2023, 09:52 AM | #21 |
Quarry Creeper Join Date: Mar 2021 Location: SOCAL
| Re: B-MOW's Hilux Beach Runner
Build is coming along great ... those axles are great ... I been hunting and keeping my eyes open for another deal on them. I been beating them up on my straight axle capra and they hold up great.
10-04-2023, 10:39 AM | #22 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
Loving the build B, lotsa of interesting stuff going on.
10-04-2023, 02:18 PM | #23 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
I picked up a couple sets of those axial straight kits when they had the sale. Twade talked me out of a set with some f10s awhile back lol. Got a set on both my capras too Sent from my SM-A516V using Tapatalk |
10-05-2023, 09:18 AM | #24 | |||
| Re: B-MOW's Hilux Beach Runner Quote:
Thanks smog! This will be different! Quote:
I stole my Capra axles from my Capra and put them on a GSpeed V3 rig that still isn't complete. I thought about using these straigth axle under the Capra. I think the Capra looks so much better with the narrower axles. You gotta watch that twade fella!! | |||
10-06-2023, 06:13 AM | #25 | |
Surprisingly, mounting it this way puts the rear driveshaft right dead in the center of the skid where it should be. It does fit snuggly with really no room for it to mount anywhere else. I forgot to take a pic of the front of the trans. The spur gear sits right behind the servo mount/brace with about 2-4mm gap. The spur gear cover will not fit unless it is cut to fit around the brace. | |
10-06-2023, 02:14 PM | #26 |
That looks good brian. Yeah, all mine have the spur right there close to the dsm. If i run the spur cover, i just cut the top half. Mainly to protect the wires under the body, not to worried about the pinion down below Sent from my SM-A516V using Tapatalk |
10-08-2023, 09:15 PM | #27 |
| Re: B-MOW's Hilux Beach Runner |
10-10-2023, 06:21 AM | #28 |
03-25-2024, 03:33 AM | #29 |
This has been put off for far too long. It's finally back in the shop to hopefully get much of the mock up done and get it to the paint shop. |
03-25-2024, 06:14 AM | #30 |
Very cool build. So you're a big fan of the S8E shocks, huh? They seem to be love it or hate it depending on whether or not you can prevent them from leaking. At $99 the axle set is a good deal. At $169 it is a tough sell for me. Axial can keep the shocks. I don't think Axial has made a shock that doesn't leak. This is probably exactly why you chose to use S8E shocks instead. |
03-25-2024, 06:47 PM | #31 | |
The Axial axles were a great deal at $99. I bought 3 sets that I have used in other builds. I probably wouldn't buy them for $169. I'd spend more and buy the Vanquish F10's before I'd buy the Axial. I didn't use the Axial shocks that came with the axles because they are 100mm. I still haven't figured out Axial's thinking why they decided to go that long. I did use 1 set of these shocks in another build and ended up using fuel tubing to limit them to about 90mm. These shocks are OK, but will never be my first choice. | |
03-25-2024, 08:25 PM | #32 |
Rock Stacker Join Date: Oct 2019 Location: Coastal South Jersey
As a life long surfer and rc nerd I will be following. |
03-26-2024, 03:31 AM | #33 |
03-27-2024, 08:03 PM | #34 |
Before I jump back into this build at full throttle, I first want to go back and get caught up on what has already been done. Before it sat in my other garage over the winter, I had tinkered with on and off and got to where it sits now. The chassis as it sits now. Mocked up and drivable. Battery location up front beside the servo. I used a piece of Kydex and foam strips and attached it to the winch servo mount. A Hobbywing 1080 G2 ESC and a Holmes Hobbies Crawlmaster Sport. Added an extension onto the rear chassis to mount the rear bed support and bumper. Mounted a set of Mickey Thompson Baja MTZ tiny tires mounted on a set of plastic wheels that I painted with Rust-oleum Hammered silver paint to replicate aluminum wheels. Top look of the VFD Twin with the piece of Kydex that is mounted to the underside of the top gear cover. I decided to swap out the Tamiya Hilux body and Marlin bobbed bed for an RC4WD TF2 body kit. In order to haul the surfboards in the bed, it'll have to have a long bed. At the time I bought this body kit, Amain had a deal on this body kit that I couldn't pass up. Instead of using the RC4WD square headlight grille, I'll be using the Tamiya round headlight grile. I like this grille and bumper better and will fit the look much better. I 3D printed a surfboard rack that is bolted into the bed. I'll have more on that later. A quick peek at the interior. I started painting and detailing it. Carpet and a seat cover is going in next. And finally a look at the 3D printed surfboards that I will be using. The gray one is primed and sanded and still needs finished. Hoping to have more updates sooner than later! |
03-27-2024, 08:58 PM | #35 |
Rock Crawler Join Date: May 2021 Location: NorCal
This is a fun build! The kydex under the transmission cover, is this acting as a gasket?
03-28-2024, 09:53 AM | #36 | |
No. I’m using it as a place to mount my wires. I put bends in the Kydex to step it down to keep it low. I used the same piece of Kydex in my Rock Pirate RC build to mount my receiver. Sent from my iPhone using Tapatalk | |
03-28-2024, 04:51 PM | #37 |
Thats a pretty slick idea with the kydex brian. The surfboards turnded out nice. Good to see this build back on the bench Sent from my SM-A516V using Tapatalk |
03-28-2024, 05:54 PM | #38 |
Ah dude love it! Love little mods like that.
03-30-2024, 06:10 AM | #39 | |
So, scrolling thru my phone gallery I found some forgotten pics I took last year while I was working on the Hilux. Before I decided to ditch the Tamiya Hilux cab, I paired it with the RC4WD TF2 long bed. I didn't like this cab because the door handles were molded in to the body and other little details. The TF2 cab allows for the the add on details that this body doesn't have. Also you can see the cheap plastic wheels that I used. I sprayed them with paint to mimic alum wheels as it sits currently. Electronics that I choose to install. This will be my first 1080 G2 ESC so I hope it is just as great as the version 1. I picked up the Tamiya Bruiser parts tree for the bumpers. These bumpers look much better than the RC4WD bumpers that were supplied with the kit. The second pic shows the difference of the front bumpers. The TF2 is on the bottom. It is a tad wider and doesn't have the front license plate cut out like I was wanting. And I'll be adding a roll bar to the bed. Found this cheap, but nice one on the Amazon. Even comes with a light kit to add to the top to give this Hilux an '80's look. | |
03-30-2024, 09:42 AM | #40 |
Hey, Brian - you have a link for that rollbar? Ummm... and maybe for those plastic wheels? |
Tags |
1.9 scaler, bmow71, rc4wd hilux, tamiya crawler, vanquish products |
B-MOW's Hilux Beach Runner - Similar Threads | ||||
4S TRX4, Element 4 Runner & 10.2 Honcho Beach Bashing | Hardcoretam | Videos! | 0 | 11-08-2020 04:32 AM |
Hilux crawling at the beach | summitcrawler | Scale Videos! | 2 | 01-02-2013 10:54 AM |
surf brawler hilux at the beach | seven.two | Videos! | 2 | 02-05-2011 04:46 PM |
