04-19-2007, 09:20 PM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Connecticut
| Scale/Trail class 1.9 Mercedes G55 build up
Im holding off on doing my 2.2 chevy as i think i will be building a 1.9 fj cruiser instead. For now, im building my 1.9 Merc. I finally got more stuff in and am mainly awaiting my tlt, and then I just need electronics and im ready to go. This will eventually compete in the scale class but for now it will be in the trail class. It will be 4 linked front and rear so expect it to perform very well. It will run 1.9 Swampers on HPI stock car wheels. Not the best but look awesome. I will most likely keep the spare tire in the rack. The rack holds: spare driveshaft shovel cooler w/ ice and 3 budweisers jumper cables rope tow strap fire extinguisher Chassis is a MFM scale chassis with RC4WD R2 tranny. Chassis is 15" long and fits perfect in the body. Center clearence should be great as the tranny is above the lowest point on the rails. It will also have turned down tlt shocks and I will make a center skid plate. I need to rewire the lights as im having problems with the stock bulbs(one is no longer working). The tires should tuck pretty good into the wheel wells so it should look very scale if I can get it to all work out as I want it too. Will post when more is done, for now drool over some pics. |
04-19-2007, 09:23 PM | #2 |
Rock Stacker Join Date: Nov 2006 Location: las vegas/ Henderson
looks like its going to be a cool build |
04-20-2007, 03:23 AM | #3 |
Quarry Creeper Join Date: Jan 2005 Location: GUAM
looks cool when are we going to see more pics of your project |
04-20-2007, 03:38 AM | #4 |
RCC Addict Join Date: May 2005 Location: the land of the midnight sun
Looks cool over here too James. |
04-20-2007, 08:52 AM | #5 |
Looks like a great start. You will love this thing I cant get enough of mine. I wandered how that body would look with a roof rack, been contemplating getting one myself
04-21-2007, 07:40 AM | #6 |
Im pulling my comp rig apart to use the axles on my scale rig for now. Once I get my other tlt ill put axles back on my comp rig. I purchased a 55t lathe motor for it and an LRP Runner Reverse waterproof speed control. I also got my hooks and shackles in from WP Marine.
04-21-2007, 09:21 AM | #7 | |
Newbie Join Date: Apr 2007 Location: San Fernando Valley
| G-Wagon body Quote:
04-21-2007, 09:33 AM | #8 |
Quarry Creeper Join Date: Jan 2007 Location: New York
where did you get the tires?
04-21-2007, 11:08 AM | #9 |
Body is from Walmart RC car and the tires are from the Jakks Flywheels that are discontinued. The tire in the pic is a Wrangler MTR but I have a set of the swampers coming to me for this build.
04-21-2007, 11:59 PM | #10 |
Its almost a roller...tomorrow I need to figure out a way to mount the body and install my elelctronics. Then i just have to wait for the tires to arrive and i can run it. Its turning out very good so far but its hard to tell what it will look like when only rims and no tires are on the axle Pics tomorrow! |
04-22-2007, 06:17 PM | #11 |
Well its almost done as far as getting it running. There is still a good amount of scale stuff I want to add. I havent installed the spare tire, clevies' front and rear, winch and fairlead, and I need to redo the lights. Most of the pics dont show the whole rig because I only have 1 tire. The rest are just rims. So its sitting just a bit lower than it would. Chassis shots: The aluminum angle with the slots screw directly to the inside of the chassis. There are two body posts screwed into the top rear of the truck. They go into the rear aluminum angle with the holes and foam protectors and then a body clip secures them in place. There are NO holes on the body to give a more scale appearence. There is a slight amount of bumpsteer with this setup but not much to make me upset. In order to get the R2 tranny in without interfering with the four link setup I made a mount out of aluminum angle and used two screws on the bottom and one on the side. The CG is a little higher but its not too bad. Im waiting on my Swampers and Wranglers to arrive! Then I just need to install deans on the esc and solder the motor wires and ill be off to run. Its running: Elite 1500mah 6 cell 2/3 pack LRP waterproof AI Runner esc 55 turn but might go to a 45 turn metal yokes all around Duratrax shocks Hitec HS-925MG Spektrum DX3 |
04-22-2007, 06:37 PM | #12 |
Looks great! How do you think those tires are going to work?
04-22-2007, 06:42 PM | #13 |
I had them on my highlift and they did pretty well. Ill probably have Xtreme make me 1.9's out of some 2.2..not sure which one yet. The ride height will be a bit higher once all the tires are on. Flex is great as it tucks the tire right into the wheel well which is perfect! I also have to make a center skid plate.
04-22-2007, 08:15 PM | #14 |
Rock Crawler Join Date: Aug 2006 Location: nc
i have 3 of those wranglers and 1 bogger nib. pm if you want them
04-22-2007, 09:36 PM | #15 |
04-22-2007, 11:16 PM | #16 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
Those flywheels? Man there are tons of those things near my house at various locations. Never thought of using them for a scaler. |
04-23-2007, 12:58 PM | #17 |
04-23-2007, 06:47 PM | #18 |
Well its done for now...still have to do detail work on the body. I got one set of the flywheel TSL Boggers in today! They are great. I have one more set on their way along with 9 of the Goodyear wranglers. Here are some pics before and after some running. I love this truck. Flex is very scale like also. I just need a bigger pinion because its too slow. I need a bit more wheel speed. My new baby: Still on the list: tow points(clevis') high lift jack tow strap chain w/ hooks sleeping bags Hope you all enjoy it. During the build I kept wondering if it was going to turn out ok...I couldnt be more happy with it! I cant wait to start the FJ Cruiser next. |
04-23-2007, 07:08 PM | #19 |
RCC Addict Join Date: May 2006 Location: California
That is awesome! I like the way the tires tuck into the body. And it actually looks like a real truck, unlike some scalers that look like they have a 20 inch lift.
04-23-2007, 07:36 PM | #20 |
